Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth not powering up
I've tried over and over again to power up the b-tooth without any luck. 'power up failed' keep coming up and when i go to 'find me' -the response is the same. help me please!
  • 47 Answers
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Posted on Nov 24, 2008
My nokia 5800 can't find the bluedio AV890!!!!
may be due to the difference in blue tooth standards. if this then not any chance of connectivity.
Jun 29, 2011 | Nokia Lands Phones
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Will not bluetooth
"The bluetooth radio failed to turn on due to insufficient driver memory"
Rename or delete BTSDKCE30.dll and BTCORELF.dll in the windows directory of PDA
Jan 18, 2009 | HP iPAQ HX4700 Pocket PC
Blue tooth synch
error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again. If you have the cd it isnt that hard to do. go to crackberry.com and type that error message 523 and their are a lot of full detail restore posts there good luck.
Jan 07, 2009 | Cell Phones
Problems connecting Plantronics Explorer 320 to my PS3.
Hold The Key On The Blue Tooth Till It Flashes Red and Blue Then Search For It. Once Its Found Click The Power Button On The Bluetooth Again.
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
Motorola k1 bluetooth power failed
blue tooth needs to be turned on from the connectivity section of the phone menu.
Once it is turned on it will pair with any bluetooth device.
PAIRING A BLUETOOTH
Go to connetivity in the menu
then bluetooth and then search and sellect search.
with your bluetooth device from the off status press and hold the power button until indicator lights either flash different colours ( normally red & blue ) or stays a constant colour.
Your device is now sending out a signal for the phone to pick up.
when the phone finds this device it should then ask if you wish to pair with it
select yes
then it will ask for a passcode this is normally 0000 or 1234
then select yes.
this should pair up the two devices.
once they are paired you should only need to turn bluetooth on on the phone and power up the device and they will automatically find each other.
Please don't do this whilst driving as it is extremely dangerous to take your concentration off the road.
Oct 31, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Bluetooth problem
I have a motorizr z3 that I purchased a week ago. I cannot get the blue tooth to turn on. I ONCE got my Plantronics bluetooth synced but it would never turn on again, so I deleted it off, and now everytime I try and turn bluetooth on, I get a message of "Bluetooth Power Failed - try again later". It tells me the same thing when I try Setup or Find Me...any ideas how to get this to work?
Oct 13, 2007 | Motorola Cell Phones
Motorola Mobility RAZR V3i Cellular Phone Logo
168 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
