Question about Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
After loading some programs & updates onto my Garmin 3600 one of the programs I loaded initiated what amounts to a hard reset. Now I cant get the PDA to boot up. The "Palm Powered' screen flashes every second and it's done this for 24 hours. I've tried soft resets as well as hard resets and it still does this.
  • yehguaccm Apr 04, 2008
    After the battery died from being away from both the car and desktop charger for too long and after a recharge I started it up and if froze. I restarted with the stylus probe and from then on any time I start if up it continually reboots every second with the Palm OS screen reappearing. Is this a software or hardware problem? It has suffered two short drops but they were months ago.
  • dutchstar2 Jul 09, 2008
    Hi: Has any one helped you with the problem, please let me know what to do. Thanks
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Posted on Apr 30, 2007
Garmin iQue 3600 has a blink screen
if it will not power up, you don't have many options.
unscrew the head of the sylus to access the rest tool
Press the reset at the back with the stylus
This is re-booting, all data safe still here.
Hard reset is last resort...data erased here.
Press the reset button again as above
after you release, press the power button, keep pressing until the message
( all data stored is about to be erased )
to complete the reset press the upper half of the scroll button, on the front,
The digitizer screen appears
pressing any other button here performs a soft reset.
Update it if you get it up and running.
Hope this helps
Ric.
Mar 22, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
IQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Sep 23, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 Hard Reset problem.
Hold POWER button down while doing a RESET. On restarting all should be OK
Sep 12, 2008 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 mapsource Synch problem with XP
Are you running Vista? If so, contact Garmin for a download that allows the maps to be loaded.
Apr 13, 2008 | Garmin iQue 3600 GPS Receiver
When GPS is turned on unit locks up
I had losts of lock ups when flipping on the GPS - almost ready to get rid of the Garmin IQUE 3600 since it hasn't worked well for over a year. Sometimes it works a short time with the GPS; other times it was instant lock up when searching for satellites.
I took many steps to isolate the issue, and then added complexity to the equation: update to r6 (no change), hard reset, no user data on IQ3600 during testing, use only internal drive, only use basemap lite on internal drive, only use 1 local city on internal drive, load other maps on external card. Each time I went outside and flipped on the GPS to see if that was affecting the lock up.
Then I played with the GPS settings. The factor that seems to solve the issue: TURN OFF WAAS - it is intended to improve accuracy to 9 ft but it seems to have a bug.
Garmin
Ique 3600
Palm OS Release 5.2.1r6
GPS lock up crash bug
Sep 18, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
Did you try to do ANOTHER hard reset?
Aug 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
144 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
