Question about Stoves (161221) Heater
Overfiliing of ash and clinkers
My Trailblazer 1600 fills the hopper with ash and clionkers in 12 hours and has to be shut off and cleaned. It has two feed screws marked H and :L . I turned the L screw counterlcockwise to slow the feed but it seems to be worse. I have no manual. Can anyone help us please?
  • Anonymous Dec 27, 2008
    i have the same problem i need help to
The thing in the middle put it open up so that it get air use a screw to hold it wide open it will run all day and set th l h to 8 sec and it will work cherry i been mess with the stove for two years i just got it to work 3 weeks ago lol
Posted on Dec 27, 2008
Add toner problem
Clean the toner hopper and check the dev gears on the drum unit. Usually thats the problem why its not loading toner.
Jul 14, 2014 | Ricoh Aficio Mp-1600 Copier
Saeco Giro flashing
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed, the service door is open.
on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Coffee Makers & Espresso Machines
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
My engine light is on my 2005 trailblazer and if I drive 10 or 12 miles it will shut down and I will have to wait at least 30 mins to an hour for it to start back again. At first the etc light came on now...
well you have to scan your trailblazer to see what codes are set on. T hats what you have to do when a light came on Cuz engine light could be on by many reasons
Jul 28, 2010 | Chevrolet TrailBlazer EXT Cars & Trucks
12a cadridge refilling process by syed khaja moin from india skhajamoin@yahoo.co.in
Separate cartridge into 2 sections -drum /cleaning section, and toner hopper.
Replace drum and cleaning blade, clean PCR.
Remove Mag roller. clean out toner hopper, clean mag roller, replace doctor blade, fill with toner, and reassemble
Apr 12, 2009 | HP LaserJet 1020 Printer
I have a 12 cup cusinart grind & brew. The hopper is not working
You may have to clean the grinder....even more. That happened to me once. First I cleaned out the coffeemaker with the brush, and "dug" out more coffee, then I used this product which you can find on Amazon: "Urnex Grindz Coffee Grinder Cleaner - Urnex 17-GRINDZ12-40." It's expensive, but it really worked well.
Apr 02, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I cannot figure out how to use my cleaner floor mate
At the risk of giving a simplistic answer, let me go through the steps I go through every time I use mine:
1) Plug it into the wall
2) Take out the upper "hopper" and fill it up to the fill line with hot water
3) Put in the capful of cleaning solution (about 2 oz.)
4) Gently swish it back and forth, then put back into upper unit until it clicks into place
5) For best results, set the vacuum on Dry and vacuum the house first, then clean the lower "hopper"
6) Set the vacuum to Wet, put the scrub brushes on, depress the trigger and do overlapping strokes, a section at a time I depress the trigger on the push stroke, then release it for the pull stroke. I clean a section, then turn off the scrub brushes and go over it again without the scrub brush or touching the trigger (trying to pick up as much water as possible).
On average, when refilling the water/cleaner solution for the top hopper, empty and clean the lower hopper. When the floors are finished, completely clean that lower hopper or it will smell!
Hope this helps...
Jul 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Heating & Cooling Logo
41 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
vance jones
ghold1
Level 1 Expert
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
