Question about Samsung 793DF 17" CRT Monitor
Pink horizontal stripes on my monitor
I have a problem, pink horizontal stripes appear on my screen every now and then. Sometimes the screen goes completely pink, everything white becomes pink basiclly. I have no idea what the problem is but it's really annoying. Please help, thankyou. :)
  • Henrik Elenius Dec 30, 2006
    which is the deagus button?
  • Anonymous Mar 26, 2014
    horizontal at the bottom and 1.5 inch in size
    President:
  • 2,961 Answers
If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
Posted on Dec 30, 2006
  • andrew pester
    andrew pester Dec 30, 2006
    it will be on the same menu as brightness etc, of your monitor and look like wavey lines on the menu icon
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
A small pink stripe down the left side of my HP laptop display screen. What's up??
It probably means that you're very lucky that your screen is failing and probably NOT the Video Card on *********** board. Either borrow a monitor and hook it to your computer (and see if the line appears on the borrowed monitor...if not, you know your monitor is failing) or take your computer to a friend's place and hook it to his/her monitor which will produce the same troubleshooting answer with the reversed conponents, if the line appears on his otherwise normal LCD, your video card is the problem.
Best Regards,
TheSelkie
Oct 03, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Need to know what the pink and yellow wires are in computer cables is one earth other live
Here are the wire Color code for AC primary side;
US: Black = HOT/LINE, White = Neutral, Green or Green with Yellow stripe = Earth ground/safety ground.
Euro: Brown = Hot/Line, Blue = Neutral, Green with Yellow stripe = Earth Ground/Safety ground.
Feb 12, 2010 | Mass Multimedia Open Box C3H TRIPLE...
The monitor is pink
Check and reseat the monitor signal cable. From the computer. If after reseating the signal cable the problem is exibited .It would require more inspection. Could you mention the model number of the acer monitor you are using
Thanks
Proton
May 29, 2009 | Acer Monitor
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
SCREEN FLASHES, PINK STRIPES , SOMETIMES BLANKS TO BLACK THEN ON
This issue could be either the Monitor inverter failing or it could be your Video card. If you have another computer available, plug the monitor into a different computer and see if you get the same behavior, if you do, then the monitor is failing and needs to be replaced. If on a different computer it works fine, then you may have a video card failing. Does it seem to happen the longer the monitor is on? Could be as it heats up, it starts to fail.
Mar 03, 2009 | Dell E153FP 15" LCD Monitor
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung 793DF 17" CRT Monitor Logo
289 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
