Question about Take 2 Interactive The Da Vinci Code for Windows
Sheild Problem How can i solve the shield grid puzzle?
    Problem Solver:
  • 10 Answers
I haven't really played the game but I can provide you with a link that may help you solve it. It is here.
Posted on Nov 26, 2008
I just want to know on my cm 918t that i got this right the wht and yello wires have a center and a sheild yes and thx
Black negative/ground,
Red +12V,
White shielded =Audio out, centre white to centre pin of Rca plug shield to outer rca,
Yellow Shielded = video out centre yellow to centre pin of Rca plug shield to outer plug.
I have no idea what your question is but hope that's what you wanted to know
Jun 22, 2014 | Cars & Trucks
How can i remove the hotspot shield from my pc
Hotspot shield is an installed program.
Open your control panel and click on 'uninstall programs'.
Look for hotspot shield in the list of programs, right-click on it and choose 'uninstall'.
Follow the prompts, if any, to uninstall hotspot sheild
Jun 02, 2014 | Computers & Internet
Expat sheild will not install due to compatibility issues
Did you uninstall with a program like Revo uninstaller? That program finds files that are often left behind with a routine uninstall.
Jan 20, 2013 | AnchorFree Expat Shield
Catylistic converters heat sheild
the heat shield protects the floor board of the car from getting to hot, and it
willnot hurt a thing if you remove it.
Jun 19, 2012 | 2003 Pontiac Vibe
Beringher CT100.. X Pattern on LED grid when testing an xlr cable
This site has diagrams... not the best but clear enough.
PLEASE note that the pin numbering is kind of goofy... The pins of both the male and female tie to identical pin numbers.
You PROBABLY have misread the numbering at one end.
A KEY thing is to get the shield on pin 1 at both ends.
I recommend that you uncap BOTH connectors, mate them, and verify the same color goes straight across as you solder the wires..
Note: I had some brand new cables delivered that the shield had been connected to pin 3 (middle one) and I had hum ! Note that this defect would NOT be caught by your cable tester as there was conituity between corresponding pin numbers.
May 04, 2010 | Behringer Ct100 Cable Tester
Loose heat shield
Most likely it's a heat sheild on the converter, maybe the muffler. 1 on top and 1 on the bottom. The heat sheild is welded to the converter, over time they rust away, around the welds. You can use a large diameter worm gear clamp to keep the heat sheild from rattling. The sheilds are in place so if you drive over grass, the heat from the converter won't ignite the grass.
Mar 14, 2010 | 1997 Honda Accord
How to change the rear 3 spark plugs on a Buick regal LS 2002
metal sheild comes of with sparkplug wire,just spin and pull should come out then remove sheild and slide on new wire and connect back to plug,its just a slide on heat sheild.good luck.
Oct 04, 2009 | 2002 Buick Regal
Bitdefender Sheild
Many hrs of trail & error
May 27, 2009 | Dell Axim X3 Pocket PC
I cant disconnect my shield w/ power supplyboard from tv
There is nothing easy about this repair, I am a tech and allow 2-3 hours even now after doing many times.
Start with the sheild on the right, closest to the light engine. you will need to loosen the input jack board to get this sheild off.
2nd remove the middle shield, you will need to unplug the fan attached to it. Now you can remove the one over the power supply.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Where to find replacement Diamond Shield at reasonable price
My Mitsubishi Diamond Sheild also had scratches on it, and I solved the problem at no cost by taking some automotive wax, and hand-polishing the shield with a smooth rag (old t-shirt works great!) Leave it right on the television, no need to take it off.
HINT: Don't leave wax on too long, and just do a small section at a time.
Feb 18, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Take 2 Interactive The Da Vinci Code for Windows Logo
89 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
shaun
shaun
Bill Boyd
Alex Korvinus
Alex Korvinus
Level 1 Expert
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
