Question about ECHO, Inc. PB-251C Handheld Blower
Blower smoking and won't run
My blower will not stay running and when I increase the throttles it dies out. It's blowing a lot of smoke...broken ring?
Thanks,
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    is it a 2-cycle motor? (gas and oil mixed together)
  • 23 Answers
Bad plug. even worse gas.
2 stroke oil breaks down and makes the fuel dirty after so long in the gas can. Also check your filter to assure its not got alot of leaf debris. -Jeff Anchorage Small engine repair.
Posted on Feb 04, 2009
1997 mazda e2000 van which is blowing black smoke
if it takes 5-10 mins of running before black smoke disappear i think you could have broken rings causing engine oil into the combustion chamber. you could observe white smoke if you have just changed oil.
solution would be to replace piston rings. it would save u a lot if u could diy.
Nov 24, 2013 | Cars & Trucks
Mower will start but blows lots of white smoke and dies when throttle is moved to full
sounds like to much oil but you say the oil level is fine. you may want to check the compression on the head to see if the head gasket is blown. if there is a lot of smoke or oil blowing out the oil tube, that is a sign of blown head gasket.
Nov 27, 2017 | Ariens Garden
Have 82 ford truck f150 runs for abut 5-15 mins than dies getin gas chang full pups two times same thant runs and die
Hmmm...maybe piston ring failure, valve seal failure, rich air/fuel mixture or maybe a head gasket (however that is normally white smoke due to coolant burning instead of oil). If it's so dark that it's almost blue then I can tell you that somehow oil is getting into the cylinder and burning alongside the air and fuel. Your best case scenario is that the engine is running rich (Rich:Too much fuel, Lean:Too much air) and the smoke is a dark grey to black color. CAUSES OF SMOKE
Dec 28, 2012 | Ford Cars & Trucks
Heater vents blow blue smoke and smell of burnt leaves
Check you cabin filter it is under hood on pass side near wiper blades
If the blower motor is running fine and no smell from there.
Dec 14, 2011 | 1992 Ford Explorer
Chevy Aveo strange smell and smoke coming through the vent with air conditioning on. Checked engine-OK. Turned up air conditioning full blast...after 30 seconds...little more smell and smoke it stopped...
If the blower motor is still working, that was not the problem-the strange smell might have been from some bacteria in the plenium, and the smoke may have just been the result of condensation from the evaporator in the plenium-keep an eye on it, but if the blower is working, I would not be overly concerned about it.
Jul 20, 2011 | 2005 Chevrolet Aveo
My lawn mower gcv 160 run for 3 minutes and die,has to wait some minutes to start again
does it blow blue smoke= sounds like over fueling, so you need to get the carby a service.
if not blowing smoke= *sounds like over heating. check to see if the cooling vents on the side of the engine are blocked eg wasps nests. if it has a radiator, check the water level and then look along the front and back to see if it is blocked with grass. if so blow out with hose or air blower.
Mar 13, 2010 | Garden
Leaf blower will start, run for about 3 secs, then dies. Blue smoke comes out of it.????
blue smoke is the sign of burnin oil try putting oil in thr cylinder about two tablespoons of oil the blower should run long enough to the oil is burned out that will tell it is the rings but sometimes it will free the rings and keep on running if your lucky
Nov 06, 2009 | Yard Man Garden
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lots of smoke and low power
turn the choke off. then adjust the throttle cables.
Jan 19, 2009 | Toro Blowers Rake and Vac - Electric...
ECHO, Inc. PB-251C Handheld Blower Logo
1,234 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
