FIRST CHECK YOUR FUEL PUMP TO ENSURE IT IS WORKING PROPERLY, THEN DO A FUEL PRESSURE TEST. AN AVERAGE READING WILL READ BETWEEN 15 AND 30 LBS. THEN YOU NEED TO BE MORE SPECIFIC IS IT GAS OR DIESEL IF IT IS A DIESEL THEN YOU NEED TO LOOK INTO INJECTOR PRESSURE THE AVERAGE CUMMINS COMMON RAIL PRESSURE AVERAGES AROUND 5,000 TO 8,000 PSI ANYTHING LESS THAN 5,000 PSI THE TRUCK WILL NOT START OR WILL BE HARD TO START.
