Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca 52' projection screen
My screen blew out when i moved and shattered. can the whole front screen be replaced along with the circuit board inside, and could there be any internal damage?
  • RCA Master
  • 8,617 Answers
Yes your can get replacement screen assemblies with the frame and front panel board already installed at the following link just leave them a email with what youre needing and what the model number of your set is. Heres the link.
Posted on Nov 24, 2008
the rca model itc222 chasis cord or plug runs to the front mains doubler board. this small narrow board is located in front of the large main green board. this board is a small narrow circit board behind that main board... on the right of that board there is the main fuse. next to this is the plug that the main cord plugs into
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Problem with the RCA D52W20 52 in. Rear Projection HDTV-Ready Television. Was told that I need a deflection board for my tv. Where can I find one and how do I know it's the right one?
This Model has 8 different Last # D52w20yx1 ect,What is the complete Model number That is printed on back of TV?
Deflection Board is the Bottom left handside Board,it will the FBT flyback Transfomer on it.
Look up on the front of board for Bad Capacitors CP150 CP114 CP120 if any of these Capacitors are Vented or puffed up on Top then replace all 3 caps,resolder FBT Pinns.
Caps 2200uf 16v, 220uf35v, 330uf 35v.
PTS this company rebuilts boards. 1-800-844-7871
UED 1-800-648-6657
Let me know what the whole Model# is and then I can run it to see what comes up for PN#
It is very inportant to have correct model# RCA made over 37 different deflection boards and (52) SSB boards. If you decide to ship your board make sure you write down the number that is on that board.
Mar 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv is blurry
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
May 06, 2010 | RCA P52926 52" Rear Projection Television
Rca screen projection tv will not turn on what can I check
There is 3 capacitors on power/deflection board cp150 2200uf16v look to see if it is puffed up on top if so replace 2 more caps aswell in same circuit cp114 cp120 220uf 35v.
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
It just plugs in and try cleaning contact switches first with contact cleaner see if this fixes it.
Dec 19, 2008 | RCA P52937 52" Rear Projection Television
Rca big screen, no power light,, dead!
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52w26
Your CRT leaked on the board. You will need to replace the seal as well as the board which got leaked on. Can you post a picture of the board and I will post the board number as well as post a link where you can get another boards at.
Apr 14, 2008 | RCA P52926 52" Rear Projection Television
RCA P52937 52 in. Rear Projection Television
remove the speaker grille. then there should be a few screws running along the bottom of the screen frame. after removing those screws slide the entire fram up to release the hooks that hold the screen frame to the cabinet. Be careful and unhook the wire clip from the front control panel once the screen frame is loose before you stretch the wires.
Apr 13, 2008 | RCA P52937 52" Rear Projection Television
Convergance circuit board
you dont need a new board just replace convergence ics that would be the way to go will cost you under 75.00 if you do it your self if you take it in it will cost you 250-350 depending on the shop
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
