Question about Acer Aspire™ T180 PC Desktop
Acer AL 1917W- Same Problem
Your Problem is my problem....Did you find the right Setting?
I cannot find an adjustment to make round objects on my Acer AL1917W monitor look round. It's a simple request, but I have been looking at egg-shaped round items and stretched (horizontally) pictures for a month. Buttons on front of monitor are no help, and driver software offers no adjustments.
    Problem Solver:
  • 5 Answers
Use the display /settings control to change the monitor resolution to 1440 x 900.
Please post here with positive or negative results to this as there are other factors which will take more explaining.
Posted on Nov 26, 2008
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Acer aspire 5515 laptop can not focus monitor.
go to display properties and goto setting and set a resolution 1024*768 if it not works goto advanced and set dpi to normal size (96 DPI)
Aug 01, 2009 | Computers & Internet
Input not supported is floating round my monitor screen how do i get rid of it
You probably need to change the resolution setting in your computer display settings to a setting that is supported by the monitor.
Your resolution setting right now is probably too high to be recognized by the monitor.
1440x900 should be the resolution setting for an AL1916w if your video card will allow that setting
Fran
Jul 19, 2009 | Acer AL1916W 19" LCD Monitor
How to adjust time, day or alarn on Kenneth Cole KC2516 digital watch
There are 2 buttons on the right side, depress the lower round button twice with a pointed object (like a pen). Only one number should appear (month) advance if desired with the top square button. Depress the round button again (once) to advance to next number and advance, continue this until you complete the settings.....
May 10, 2009 | Kenneth Cole KC2315 watch
Round things are shaped like eggs
This is a widescreen monitor. To get the display to look right, you need to install the software that came with the monitor, and set the resolution to the manufacturer's recommended setting (the monitor's "native resolution"). I don't know what that is for the AL1917W. I have the AL1917, not the widescreen. A friend got a 21-inch widescreen and had the same trouble as you until we set it to the proper resolution. (And it looks great and I'm jealous!)
Nov 17, 2008 | Acer AL1917W LCD Monitor
Acer LCD Monitor AL 1917W A
Check out the power cable for any damage.
There may be chance of damage of data cable, and because of that there may be no display in ur monitor too.
If all fails, then the power unit inside ur monitor may be blown.
Oct 18, 2008 | Acer 91.63X07.001 Keyboard
Setting alarm
Alarm can only be set or disabled when the power in "Standby" mode. The manual refers to it as power "off" mode, but the LCD display will still be readable only darker. To set the alarm push the Standby button until the sound stops and the LCD is dark. Then push the AL SET button (which doubles as the volume down button when the power is "on"). The hour should start flashing. Adjust the hour by using the two buttons at the bottom on the right side just above the IR sensor. Once you've set the hour, push the AL SET button again and similarly adjust the minutes until you have the right time that you want the alarm to go off. Now push the AL SOURCE button (which also doubles as the function button when the power is "on") to toggle between Radio, CD, iPod or buzzer for your alarm. After you're satisfied that the time is right and the source is right push the AL SET button again. The LCD should still be dark, but should also show the word "ALARM" in the upper left hand corner.
To set the unit so the alarm doesn't go off push the "Standby" button until the sound stops and the LCD is dark. Push the AL SET button until the hour is flashing. Don't bother to adjust the time, just push the AL SOURCE button until none of the following appear: CD, iPod, Radio, Buzzer. As you push the AL SOURCE button it will toggle between these options. Once you're sure none of them appear on the left of the display, click the AL SET button again. The LCD should still be dark, and you should not see the word "ALARM" in the upper left hand corner.
Jul 04, 2008 | GPX HI2817 Shelf System
Hoe do I remove teh attached stand on an ACER AL 1913?
Where the footpiece joins up with the screen, you'll find a round cover from left to right which just clips in. carefully squeeze the ends and pull away untill released. under the cover you'll find four screws that holds the footpiece and screen together. Good Luck, jus004
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
Acer Aspire™ T180 PC Desktop Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
