Question about Toshiba Satellite A135-S2276 Notebook
The answer of 1/81c raise to 3 d raise to 2 - c raise to 5?
What is the best answer
  • liz_198576 Nov 24, 2008
    i want the best answer
  • OldMycroft
    OldMycroft May 11, 2010
    What is the question?
How do you solve roots on the calculator?
If you want to raise a number to a power, use the ^ key just above the divide key. For example, to raise two to the third power, press
2 ^ 3 ENTER
If you want roots, use the root function in the MATH menu. For example, to take the third root of two, press
3 MATH 5 2 ENTER
Jan 28, 2013 | Texas Instruments TI-83 Plus Calculator
What is a raised dog bed and why should I get one for my dog?
A raised dog bed is a dog bed that is raised above the ground; generally by 6 inches. These beds can be extremely comfortable, considering they are not on the hard floor. Even with excess padding, other dog beds are still essentially on the ground.
Jul 18, 2012 | Dogs
1994 chevrolet z-71 pickup/ howto replace fuel pump
Yes it is in the fuel tank. The tank will need to be dropped in order to replace the pump. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 02, 2012 | Cars & Trucks
When calculating anything to the power of zero I get an answer of -1 when the correct answer is 1.
Well, if that anything happens to be a negative number and you key in something like -3^0 without enclosing the argument -3 in parentheses then the answer given by the calculator is perfectly correct. I am just guessing what might have happened. Besides, as you well know, any number different from zero that is raised to the power 0 should yield a value of 1. Is there any point to be proven by calculating it?.
Mar 05, 2011 | Casio FX570MS Scientific Calculator
My problem involves converting in chemistry and im just trying to figure out how to do a problem 0.58 x 6.022 x 10 raised to the 23/ 1. I know how to calculate the problem just cant read the answer a more...
Press the keys:
. 5 8 * 1 2 . 0 1 x^-1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
and you should get 2.9E22. Do you get something different?
* is the multiply key on the right, between divide and subtract.
x^-1 is on the left, below MATH.
EE is the 2ND function of the , key, just above the 7.
Another way to calculate this is:
. 5 8 / 1 2 . 0 1 * 6 . 0 2 2 2ND [EE] 2 3 ENTER
This should give you the same result.
Mar 10, 2010 | Texas Instruments TI-83 Plus Calculator
How do i remove a fuel pump on a 2004 mazda 3
Hell0 dspirt1: My name is Roger and I will help. The only wat to access the fuel pump is by removing the fuel tank from underneath the car. There is no other way to obtain access to the pump. You will need to raise the car high enough to allow room for a jack of some kind and your self in order to remove the tank. This is best done on a hoist. Should you need further help please just ask. Please rate the answer you received. This way I know it was helpful. Thank You for using Fix Ya. Roger
Dec 04, 2009 | 2004 Mazda 3
Casio fx-300es---how to convert radians to degrees
You use the key combination [SHIFT][ANS] (DRG>).
If the default angle unit is degree
Type in the angle value in radian, say 1.2.
Press [SHIFT][ANS] (DRG>).
The screen displays 1: deg symbol, 2: a raised r for radian, and 3; a raised g (for grad).
1.2 [SHIFT][ANS] (DRG>) [2: raised r] .
The screen displays 1.2 with a raised r to the right of the 2.
Press [=].
The answer is 68.75493542
Dec 02, 2009 | Casio fx-300ES Calculator
Keystroke issue with TI BA II +...
ok so when you're typing it into your calc. like that don't type it in without parenthesis.
example:
2^3=8
to find the cube root of 8, you type in 8^(1/3)
DONT type 8^1/3 because that means that you raising the 8 by a one and then dividing that answer by 3
Apr 05, 2009 | Texas Instruments BA-II Plus Calculator
How do you do this exponent?
If you mean 3 raised to the power 375, sequence is
y to the power x (under OFF key)
375
Answer is "error" because the result exceeds the 9.9999.... times 10 to the power 99 limit of the TI-30XA
3 to the power 209 is about as far as you can go....
Feb 28, 2008 | Texas Instruments TI-30XA Calculator
Toshiba Satellite A135-S2276 Notebook Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
