Question about HP Office Equipment & Supplies
No response,all connection is ok.light is on.before it failed.it works alright.it print a hour ago.it ran out of paper. I fill up and it does not work again. thanks
    Genius:
  • 1,142 Answers
Reset the power that means unplug the power leave it turned off and reconnect after 5 minutes that will reset the static power.
Posted on Nov 24, 2008
How to Fix Epson Printer Error code e-01.
Unfortunately the E-01 error can indicate a hardware failure with the unit that requires repair. Either a paper sensor has failed or the printer board has gone bad, please try these hard reset steps:
Sharply unplug the printer from the wall outlet while it is still on, and disconnect it from the pc if connected there
Remove all paper from the paper feed and blow it out with compressed air a few times > With a flashlight look in the paper feed
Make sure there is no foreign object like a paper clip > Blow some compressed air inside the printer as well to remove excess dust > Very carefully double check on the far left and right sides of the printer (Where the printhead moves back and forth) to make sure no paper has jammed up in there as it often does.
Still have issues, feel free to contact Epson Printer Customer Support +1800-243-0019...
Apr 13, 2017 | Epson Office Equipment & Supplies
Error response: out of paper
Did you press "ok" or "start" after you reloaded the paper? If so, turn off the printer, unplug it from the power source for a few minutes and then plug back in and turn it on again. That should help.
Jun 21, 2009 | HP Deskjet 3845 InkJet Printer
Got MP130 series printer. Was working alright up till now, now paper goes right through without stopping and not printing anything.. When it does occasionally print, the writing is blurred and not...
My did that all the time too, but I always ran it thru the clean the rollers maintance the canon has on its driver, Did it three times then ran heavy grade of stock paper in thru there and almost always lint, dog hair, or whatever was in there comes out on the stock paper then it runs good again. ladytstarlight.
Apr 16, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Yellow Light on HP K550 indicating open panel will not turn off.
If the printer is connected to your computer - check to see if there is a blinking Red exclamation point / printer icon in the system tray. Sometimes mousing over this icon to see the tooltip is the only way to figure out what error message the printer is trying to tell you.
For us - when this happens, the printer is complaining about an "incompatible" ink cartridge - even though 99% of the time it will print from that cartridge without problems. So try removing and re-inserting all of your ink cartridges too.
Sep 30, 2008 | HP OfficeJet Pro k550 Printer
My Printer
hi dear
don't connect a printer first,
trying to uninstalling, and remove the instalation manually from program files and windows
if that not work
try to do with system restore
you can choose with date , which your computer running well
oke
Mar 26, 2008 | Office Equipment & Supplies
Paper either just rolls through without printing or won't catch and sits there
This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
MDK
Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Nov 22, 2007 | HP Photosmart 7850 InkJet Printer
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
