Weedeater mower sputters like it is going to die then comes back and keeps going though this cycle but never dies
SOURCE: mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
SOURCE: Lawn mower dies
I had a very similiar issue, try this, when the mower starts to die, unscrew the gas cap, if it starts running again, it is creating a vacuum in your fuel tank, you can get a new gas cap, or drill a small hole in it to allow a bit of air inside.
SOURCE: I have a dlt3000 18.5 intek. After 15-30 mins of
it kinda sounds like a fuel pump or fuel delivery problem
SOURCE: JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
SOURCE: Depress clutch, start mower, let out on clutch
Almost certainly it is the park break switch,i would start there.
