Have you tried while in Windows, to use the Start Menu, find Acer on the All Programs list, and locate the recovery utility? I have an Acer laptop - an Aspire - and had to do exactly that. I used the built-in recovery routine on the Acer Laptop and was able to rebuild my laptop to the condition of when it just came out of the box, brand new.It will delete all your installations since you got it, applications and documents and photos, etc., will be gone, but your laptop will function as if brand new. Good luck with it. -a.
SOURCE: Slow computer -how to restore a Fujitsu Siemens Amilo Pro v1000
If the units are running slow, you can do some maintenance on them to speed them up.
First, run defragmenter on both units.(in Safe mode)
Download ScrubXP which will automatically clear your temp, cookies and TIF files.
Download CCleaner and run it.
Run your Anti-virus program: download the free version of AVG. (Great virus protection.)
Other programs to use are SpyBlaster and Winpatrol, all of which are free.
This should help, if you feel that you need to format and restore the units, youcan do so. But try this first.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a Toshiba Satellite M115. I'm trying to do a sys. restore
Hi Imotivate!
By far the easiest, and most probably the best option for the long run is to ask Toshiba for a replacement recovery cd. It will most likely cost you, but it's worth a shot. Finding an authorised Toshiba dealer can be found by using their helpful website tool found here : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/gaspLocator.jsp?pf=true.
Hopefully this will point you in the right direction to get a replacement sent out to you!
David
SOURCE: acer aspire 3660 recovery
You can download the recovery cd files athttp://support.acer-euro.com/drivers/notebook/as_3660.html.glad to be of assistance.RICHARDM69
SOURCE: How do i restore my toshiba a105 laptop to factory setting.
if you would like to reset to factory default turn off unplug power remove battery wait 30 seconds replace batt & power hold down zero button restart pc do not release zero button until you see screen flashes and you see cursor blinking at top left release follow instructions for restore to out of box state pc will restart several times do not touch until you see choose language page this is for windows 7
SOURCE: restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
You could also try a system restore to a point before the problem started yesterday.
System Restore will allow you to select a Restore Point
(date and time) to set your system back to when it was working ok. It
does not delete any of your data, documents, music, pictures, videos or
programs (unless the program was installed after the Restore Date you
selected).
System Recovery (sometimes referred to as Factory Restore) will set your system
back to when you first purchased it. It Deletes Everything. Most
times the System Recovery does not work unless there is a recovery partition on
your hard drive created by the manufacturer. If you are trying to recover
from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall
Windows. Look on your computer for the Certificate of Authentication
(COA) Sticker. It will tell you what operating system is on your computer
and it will give you the Product Key Code (a series of 5 letters and numbers)
that you will need to activate windows. If you don't have an operating
system disk, borrow one from a neighbor, friend, relative or co-worker. Just
make sure it is the same as your COA Sticker's operating system or it will
never activate. Also make sure you get the COA Product Key Code for the
disk you borrow because sometimes the system will ask for the one that is on
your system and sometimes it will ask for the one from the installation disk.
the options appear.
You'll need to read your manual to see how to start the Factory Setting. Look for the manual on your manufacturer's website.
Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals and search them for Factory Restore or System Recovery.
None of this helps !!!!!
