Question about Refrigerators
Euroart wine cooler (JG-168BL) fault E4
I have a Euroart dual zone wine cooler JG 168BL. The bottom section is fine however the top section which normally is set at 5oC is not cooling and is showing E4 on the display panel instead of the temperature. Do you know what this fault code is referring to?
Many thanks
  • nphil70 Nov 28, 2008
    Yes the fan at the top is working. The top section is meant to range from 5 to 12oC while the bottom section approx 12 to 18oC. I think (but not sure) that the top section cools then cools the bottom section. The whole fridge is no longer cool, although the bottom section stills reads 18oC but the top is stuck on E4. when you turn it on you can hear and see the fan working but the cooling unit does not switch on.
    Thanks for that. We will pull it apart on the weekend and let you know how it goes.
  • 304 Answers
E4 - Fridge thermistor short circuit.
check this area.
Posted on Nov 27, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you checked if the blower/fan drawing air from the bottom section upwards is turning? If not, that maybe be the culprit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Top unit won't cool
Usually with thermoelectrics they either work or they dont. Not easily repairable unless you are a competent technician as the components need metering. Sounds like a heater element gone.
Apr 09, 2014 | Sunpentown SPT WC-1857DH 18 Bottle Dual...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
Why would I need a dual zone wine cooler?
The dual zone wine cooler style is ideal for keeping both reds and white wine without having to restore them in two different wine coolers.
Aug 14, 2012 | Furniture
What kind of cooler should I get if I plan on storing both red and white wines in the same fridge?
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
Jul 31, 2012 | Furniture
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Nov 17, 2008 | Refrigerators
Refrigerators Logo
565 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
