Question about Panasonic PT-47WX49 47" Rear Projection Television
Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
Hi. Our PTV (bought in 20010 has a "pinched" center section - so the edges are out of aignment (blue and red separate from green) - we have the manual and followed the set up for convergence - but it's the green crosshairs that seem out of alignment. when in convergence 2 we expected to see 9 equally spaced crosshairs (+) but the center top and center bottom are closer together than the ones on the sides - there doesn't seem to be a a way to adjust this. the result is that we get an inward arc that distorts the image and the color separates on the sides. any help would be welcome.
  • Anonymous Dec 12, 2008
    ptv problem
    Problem Solver:
Your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
Posted on Dec 24, 2008
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
What is a convergence amplifier
The convergence amplifier is a three channel Integrated circuit which controls the convergence alignment of the three picture tubes in a rear projection TV. Your convergence amps are STK392-110 there are two of them also check the six 2.2 ohm 2watt resistors
Aug 06, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 convergence amplifiers
check R7059 and R7050
check for 2.2 ohm.
if not 2.2ohm replace them.
values are 2.2ohm at 2 watts
also look for bad soldier around all serounding resintors.
Jan 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No audio or video
you have a shorted hori out put tranasistor NTE2793.
Jan 20, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at sb1216us@yahoo.com
Sep 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
PT-53WX42 IC replacement
The two convergence IC's are generic part# STK392-110 and Panasonic part# C5AA00000203. Also check for burnt or discolored resistors nearby. Since this is such an easy repair,a schematic is not necessary....The hardest part is identifying the burnt resistors and aligning the green convergence in the service menu.
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
242 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
