Question about Kodak EASYSHARE Z1285 Digital Camera
Kodak Easyshare Z1285 shutter broken
2 month old camera, new batteries, SD card working...
We can take a picture almost like normal, except when you either view or download the pictures, the image is now totally black, and the date stamp will still show correctly.
Almost as if there is a shutter that is stuck in the closed position!?
thanks in advance
-e
    Genius:
  • 2,035 Answers
Are you able view the photos taken in the camera in the display, if you have the problem only with downloaded pictures then you need check if the picture has no thumbnail or is an unrecognized format.
Good luck...
Posted on Dec 04, 2008
  • 790 Answers
Hello!!
Try hard resetting once- Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
  • Kanth raj
    Kanth raj Dec 04, 2008
    If still doesn't work then its defective CCD.You may suspect that the camera's shutter is not opening, but this is not the case.
    If u are under the warranty u can repair the defective CCD.
  • 495 Answers
Better repaired it from service center. Its not advisable to tamper with shutter.
    Sergeant:
  • 217 Answers
If the shutter is broken it is necessary to get it replaced.as if u said the device is new u can send it to service center to get it replaced.
It does not take pictures or videos when pressing the shutter button
may be you had placed the card wrong and inside the pin got pressed and only inner memory is getting used which gives less pic. due to less mb inner memory
Apr 26, 2013 | Kodak EasyShare C913 Digital Camera
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
Hello, my Finepix S1600 shoots one Picture and the little light is flashing yellow/green. When I try to shoot the second picture it blocks and wouldn't respond to anything anymore. I have to take the...
Removing the batteries or shutting the camera off while it's loading is just like shutting the power off to your computer while it's loading a page. It sure doesn't like it and can scramble its processor into malfunction. Please start with fresh batteries, format the SD card making sure the slide lock is pushed forward in the unlock position (towards the gold contacts) Load any pictures from the internal memory to the SD card, if any download to the computer and reformat the SD card. Now we have started with a clean memory. The SD card should be formatted every time you download pictures to the computer to keep things clean and running smoothly.
To the problem with not taking the picture or taking a long time to take the picture. I'm thinking you have the camera set in a "creative zone" which relays on user input and what has happened is the setting are far beyond "normal hand held photography. This meaning the exposure time is in long seconds and the camera is actually taking a picture (shutter speed for this camera can be as long as 30 seconds) I would suggest until you get use to using this camera that you turn the dial on the top to the "P" (program) mode that way the camera will look after both the shutter and aperture for the scene or subject in front of it. Another thing that could be happening is the self timer has been set for 10 seconds further prolonging what seams like forever in an exposure. See picture.
If this fails the the camera can be rest except for time/date. I'm saying this as there may be a function that has been set in the "Set up Menu" that you are not familiar with and wish nly to continue taking pictures in a more normal fashion. See the include picture which is also on page 95 of your manual.
Place picture here.
Dec 28, 2010 | FUJIFILM FinePix S1600 Digital Camera
Have a SDHC 8gb Kodak card that won't format in Z1285
It's suggested that you use any SD Memory Card formatting Software to format the SD memory card. You can download any such Software from the address given below:
https://eww.pavc.panasonic.co.jp/support/jp/sd/sdfv2003.exe
Download the software from the above link and install in your computer and then format the memory card using it. After formatting the memory card, insert it in your Camera and use it normally.
Jun 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
When I acquire pictures from SD card, it acquires
You shouldn't be leaving the old pictures on the card. That's a guaranteed way to get into trouble. After downloading your pictures, format the card in the camera.
If you want to transfer just the new pictures, you'll have to select those pictures for transfer. Since you declined to specify what software you're using, I can't tell you precisely how to do that.
May 15, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
Kodak EASYSHARE Z1285 tells me my memory card needs formatted (any card I insert) but then is unable to format them and goes back to saying it needs formatted (3 different cards)
Memory card support for Z1285: SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte.
There is no firmware available online for this model.
The last option could be that the lever on the SD card is making the SD card data protected. Please turn the lever to the correct side.
I hope it works out
Jan 28, 2010 | Kodak EASYSHARE Z1285 Digital Camera
My camra worked just fine, then when I tried to turn it on it wont turn on no matter what I do
Please try the following: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 23, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
