Question about Kenmore 62602 Electric Dryer
Reassemble dryer I just replaced the rollers on a Kenmore dryer model #11066872500. Please advise me on how to reassemble the belt, drum and idler.
  • Jodi Durachta
    Jodi Durachta Nov 28, 2008
    Thank you. It did take me a little while to figure it all out. If and/or when I have to do this again it will so much faster.
    Sergeant:
    Champion:
  • 291 Answers
To replace and go back together you need 1st put in the drum with the felt at the back, slide belt around drum, hook the idler into the **** on bottom by motor, pull idler back, loop belt though idler and over motor pulley ,,,,, it takes time if never did it before but can be done in about 10 minutes.
Larry
Posted on Nov 25, 2008
Runs but makes loud noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 14, 2011 | Kenmore Dryers
We have a Kenmore Elite electric dryer H4. For the last week it has been vibrating and making a loud noise, but still drying the clothes. Now the noise is unbearable. We can't use it. Any idea? Is it...
I believe it is your drum rollers in need of lubrication or replacement...
-----------------------------------------------------------------------ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
pulley and motor.
Please rate me------------------------------------------------------------------
Jan 13, 2011 | Kenmore Dryers
Drum is making alot of noise as it goes around . what do I look for?
pulley and motor.
Please rate me
Dryer squeals when running.
pulley and motor.
Please rate me
Jan 03, 2011 | Kenmore 62972 Electric Dryer
Machine noisy and vibrates
pulley and motor.
Please rate me
Dec 28, 2010 | Kenmore 66942 Dryer
Running very noisy with some vibration. Belt and pulley seem intact and running smooth. Roller problem? Thanks
pulley and motor.
Please rate me
Dec 27, 2010 | Kenmore 800 7983 Dryer
Noise working -problem?
pulley and motor.
Please rate me
Dec 12, 2010 | Kenmore 62602 Electric Dryer
My kenmore dryer has become so loud it hard to use with all the noise
If you have a front loading machine.
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Oct 01, 2010 | Kenmore 64932 Electric Dryer
Loud sound when spinning at high speed
Your problem sounds like drum rollers need lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Remove the filter also.
Please rate me
Aug 28, 2010 | Kenmore 63942 Dryer
Reassemble dryer
http://www.repairclinic.org/0079.asp#DiagramH
put the drum on the two rear supports
belt is diagram h
Nov 24, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
117 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
