Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture Pulsating The picture on the screen pulsates, gets worse when there is writing or titles on the screen. Picture oftens gets bigger than the screen then pulses back down to normal size then pulses back to larger size. The color scheme is also off and a little blurry but no red or blue outlines. Have disconnected the cable box and attached directly to the cable line without any change in picture.
    Problem Solver:
  • 5 Answers
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Posted on Jun 29, 2007
Why is the picture bigger than the screen?
Check the picture settings. If picture is zoomed, the effect will be like this.
Mar 21, 2013 | Vizio M550NV 55 in LCD HDTV
Pulsating pic
there is a digtal board incased in metal right behind your input board change all the 10uf caps this should fix your problum
Apr 22, 2010 | Toshiba 42H81 42" Rear Projection...
I WANT TO MAKE MY MYSPACCE PICTURE BIGGER
If the picture is, say, 400 pixels wide, and 300 pixels tall,
then one way is to write a bit of HTML code:
<IMG SRC="my-photo.jpg" WIDTH=600 HEIGHT=450>
to force the image to be "stretched" 50% both horizontally and vertically.
Nov 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
Panasonic 51 inch TV projection troubles
convergence of tv need to re adjust,
Jul 05, 2009 | Televison & Video
Screen size
YOU MUST GO INTO YOUR PS3 VIDEO SETTINGS MENU AND SET YOUR HDMI TO 1080P AND YOUR PICTURE SHOULD BE OK
Nov 02, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blue flashes on screen and then just quits
post your model. Sounds like the blue CRT is shorted. But let me know the model and I will let you know how to test it.
Apr 04, 2008 | Televison & Video
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Picture bigger than screen
This can be caused not enough high voltage going to the picture tube. If the picture seems to get larger and smaller depending on the brightness of the scene on the screen that is probably what it is. IF that is the problem, there isn't much a normal consumer can do.
Nov 08, 2007 | Samsung TXF2899 28" TV
Sony kv32s42 trinitron color tv blinking
sounds like a bad picture tube. Picture and bright settings cranked up for a good pic? Test/rejuv with a crt tester and/or look at the Ik signal on the crt board. A good tube has 3 small pulses during blanking. The crt cathodes are checked with these pulses, pulses too low and the jungle IC will blank the drive. If the picture fades in and out I would check the filament ckt but that doesn't support the "blinks"
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture size too large
Did you try chaging the aspect ratio in the setup menus yet?
Feb 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
