Question about Lenovo R61 T7300 Notebook
Listen music from wireless device
I got a sony DR BT 50 wireless bluetooth headphone & paired it with my laptop lenevo R 61 type 7734 A17 then also i m not able to listen music from laptop. kindly suggest.
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
Cant listen to music on my Blackberry Pearl using HT820
I'm not familiar with Bluetooth and Blackberry's but I think you need a driver or you need to "sync" your media player on your Blackberry with your headphones.
I'll do some research and get back to you.
Feb 20, 2008 | Motorola Mobility HT820 Wireless / Cable...
Connect sony dr-tn200 bluetooth headset to samsung mx-h620 hifi
Bluetooth is a short-range (33 feet/10 meters) wireless technology that allows two Bluetooth-enabled devices to connect wirelessly and communicate between them. If your son's Samsung MX-H620 HIFI is not Bluetooth-enabled, the two devices will not be able to connect in any way. If the headset were corded (it is not because it is Bluetooth) you could plug its cord into the headphone (LINE/AUX IN) jack on the Samsung. if the Samsung system is not Bluetooth, the only option is to find a suitable Bluetooth adapter to make it Bluetooth-enabled. However, you can use the Sony headset to listen to music or make phone calls from Bluetooth-enabled devices that you own such as phone, tablet, iPod, iPad.
Dec 29, 2014 | Samsung Radio Communications
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 | Cell Phones
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
I don't know how to work my Wireless Bluetooth Headphones. Sony(Wireless Stereo Headset DR-BT22)
I went to www.sony.com, clicked on customer support, typed in the model number of my headphones, and then clicked on the "operation" link.
A PDF file came up and told me exactly step by step how to use my headphones.
Jul 26, 2008 | Sony Computers & Internet
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Dec 11, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Bluetooth headset won't play music
hello,
All the bluetooth wireless headset are only capable of making/receiving voice calls.
Y?
its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
BT 1.2, Version playing music through a BT headset while music is playing on laptops.
and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
hope this little information helps.
TY
Nov 29, 2007 | Sony Ericsson Walkman W810i Cellular Phone
RIM has a new OS for the 8100 pearl (OS 4.3). This OS supports A2DP streaming which is necessary for listening to music with bluetooth headphones. The OS is out in beta version now and supposedly available on bit torrent. I hear that AT&T will release the OS for their phones in April or May.
Nov 06, 2007 | Motorola Mobility HT820 Wireless / Cable...
I loose BT connection after one song
Does the motorola headset make decending tones when it disconnects? If it does, you are listening to your music using the Headset bluetooth profile rather than the High quality audio one. You will need to change the way the device is paired to the phone. Try pairing it as bluetooth headphones or bluetooth high quality audio, rather than a bluetooth headset. Once you have done that, you can pair it as a bluetooth headset too, as the motorola headset connects to 2 bluetooth devices, or in this case, one device, with two profiles. To use the headset profile, press the left M symbol once, and the headset will play a sound to indicate connection as a headset. If you press it again, it will revert to High Quality Audio profile, and you can listen to your music, and even skip/pause it!
Apr 26, 2007 | Motorola Mobility HT820 Wireless / Cable...
Open Questions:
Lenovo R61 T7300 Notebook Logo
64 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
