Question about Kenmore 63942 Dryer
Reassemble dryer I just replaced the rollers for my Kenmore dryer model #11066872500. I need help on how to reassemble the blet, drum and the idler.
    Sergeant:
    Champion:
  • 324 Answers
Http://www.repairclinic.org/0079.asp#DiagramH
put the drum on the two rear supports
belt is diagram h
Posted on Nov 24, 2008
Runs but makes loud noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 14, 2011 | Kenmore Dryers
We have a Kenmore Elite electric dryer H4. For the last week it has been vibrating and making a loud noise, but still drying the clothes. Now the noise is unbearable. We can't use it. Any idea? Is it...
I believe it is your drum rollers in need of lubrication or replacement...
-----------------------------------------------------------------------ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
pulley and motor.
Please rate me------------------------------------------------------------------
Jan 13, 2011 | Kenmore Dryers
Dryer squeals when running.
pulley and motor.
Please rate me
Jan 03, 2011 | Kenmore 62972 Electric Dryer
Machine noisy and vibrates
pulley and motor.
Please rate me
Dec 28, 2010 | Kenmore 66942 Dryer
Running very noisy with some vibration. Belt and pulley seem intact and running smooth. Roller problem? Thanks
pulley and motor.
Please rate me
Dec 27, 2010 | Kenmore 800 7983 Dryer
Noise working -problem?
pulley and motor.
Please rate me
Dec 12, 2010 | Kenmore 62602 Electric Dryer
Need to change drum rollers on a Kenmore clothes dryer.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 24, 2010 | Kenmore 63942 Dryer
Kenmore 800 electric dryer makes a loud squealing noise. Could it be something other than a belt.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Good Luck,
I hope this helps
Nov 29, 2009 | Kenmore Dryers
When I turn my dryer on it has a clanking sound it drys the cloths but is loud.
Or may be an idler bracket that need to be lubricated or replaced.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, and the idler arm bracket with pulley.
Check your drum rollers for flat spots, if they have flat spots on them replace them. If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil.
Then check your idler arm bracket to look for wear or need of lubrication, if it is worn then it may need to be replaced.
Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 07, 2009 | Amana Dryers
Reassemble dryer
to replace and go back together you need 1st put in the drum with the felt at the back, slide belt around drum, hook the idler into the **** on bottom by motor, pull idler back, loop belt though idler and over motor pulley ,,,,, it takes time if never did it before but can be done in about 10 minutes.
Larry
Nov 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
124 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
