Question about EliteGroup P4M800-M7 Motherboard
Want to upgrade ram to 1gb
Dear sir
I have p4m800-m7 mb with 256 ram. now I a want to upgrade it 1gb. Can u plz suggest me which one is better (vendor/type/spee) etc.
with regards
Krishna satish
  • 488 Answers
Do look at crucial.com and use their online memory scanner..that show u all the details..just to add to what the others have correctly told u..
Posted on Nov 24, 2008
    President:
  • 1,901 Answers
You need unbuffered, Non ECC DDR2700 or DDR3200 modules. You can install single modules. You do not have to install pairs. The maximum RAM for your system is 2GB.
I would suggest sticking with one of the major brands...Kingston, Crucial, PNY.
    President:
  • 1,314 Answers
Hello. Your motherboard supports DDR PC 2700 memory. You can put 1 GB in each slot for a maximum of 2 GB. I would recommend buying a 1 GB chip. Chances are it will work along with the 256 chip already in your computer, but sometimes that can cause a conflict. Either way, you'll have 1 GB and you can upgrade to 2 GB in the future if you'd like. Here is my recommendation.
If you buy two of them, you can upgrade to 2 GB.
Thanks and please take a moment to rate as fixya.
  • EliteGroup Master
  • 4,806 Answers
Kingston Value Ram will do, nothing over 533mhz
regards
Hi, I want to upgrade my RAM from 256 MB 400MHz DDR1 (hynix) to 1GB DDR1. Do the both will work together or i would have to use 1GB alone? Im having ASUS K8V- VM motherboard. Will it be compatible with...
It will be compatible but it is recommended, you use same type of modules(RAM)
ie 256 MB + 256 MB
1GB + 1GB
Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
Apr 24, 2011 | Computers & Internet
Replacing memory on the P4M800-M7 A motherboard
No. Just make sure that you two RAM modules have the same specifications (speed, clock).
If you don't know about that, then simply insert both RAM modules and start your computer. If Windows loads, then right click on MyComputer and go to properties. If it shows 1.5GB then you are OK.
If the computer fails to start or you hear multiple beeps it means that they are incompatible.
Replace the 512 module and insert the new one and try again.
Always remember to turn off the power and unplug the cable from the power supply before replacing RAM modules.
Jan 28, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
The motherboard supports 2GB maximum memory. 1x1GB in each slot.
Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
Please remember to remove the power cord before installing the new ram.
Regards.
Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
Mi Mainboard no reconoce 2 memorias a la vez
Your Motherboard has a built in Video display unit. This display is using 64MB of the RAM you would be using for other stuff. If you want the rest of the memory to be released you will have to purchase an Off-Board Video card that is AGP and then enter the BIOS screen on startup and disable the on-board video card and the memory (there may be a jumper on the MB to disable the on-board Video). I hope you can find someone to translate this for you.
Sep 12, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Kingston KVR667D2N5/1G funciona como si fuera de 512M
Algunas placas madres tienen solamente 1 ranura de la memoria de funcionamiento aunque haya 2 ranuras en el tablero. Está usted usando 1 viruta o 2 virutas en la placa madre.
Jul 11, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Stops booting
Did you remove the components that you upgraded, and try adding them back one by one?
Will it give you a POST screen?
Does it Beep at boot time? If it is noisy try moving it to another room.
Describe the original components and then the ones that you upgraded in detail. This will allow us to better troubleshoot the problem.
Dec 02, 2007 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
102 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
