Question about Harman Kardon CDR30 2-Disc CD Recorder
Harman karadon cdr26 recording problem
This machine has worked great for 3 years..till now. When I am recording, everything I always do...
and this time.. it records only 20 seconds then shuts down with "updating" (in other words, the recording is interupted after 20 sec.
please help or any advice..appreciated
  • 105 Answers
Try to download and install a clean version of aspi32 drivers,  http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi32_exe.htm
Posted on Nov 24, 2008
  • Arnaud Gaudin
    Arnaud Gaudin Nov 24, 2008
    Posted by error sorry
No sound out the front speakers Harman kardon HS 250
If everything else works fine, than change the 47uF/50V electrolytic capasitors in the power supply, primary side. There are only three of them. C505 is the one that's always bad, but change them all to be sure.
Sep 22, 2013 | Harman Kardon Audio Players & Recorders
Looking for an internal parts diagram for a Harman Kardon CDR2
Where do you live? Sarasota electronic has belts if its wrotten take machine and belt I am in florida
Apr 03, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
I can't open the tray on the recorder side.
I had similar problem with both drawers. The belt from the drive motor to the drawer pulley is worn. mcmelectronics.com has two belts 42-1050, 42-045 that are close enough in size to work. Remove cover, press down on tray, slide tray forward about half way and you will see the worn belt. Total cost of fix is about $12.
Dec 16, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Harmon Kardon CDR26 unit shuts off
This is a problem in the power supply, various components go dry jointed.
Regards.
http://www.audiovisualservices.info/
Dec 11, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Thank You
I hope it works, but if not the only reasonable thing to do is take it in for service.
Wishing you a great day, and thanks for the compliment.
Dave
Jul 02, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Help with Harman Kardon cdr26
so u wann record u have to be in record mode 1st for signal to come throw and sorce vol up
Jan 27, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon CDR30 2-Disc CD Recorder Logo
112 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
