Question about Dell Inspiron 6000 Notebook
DC Adapter for laptop doesn't work
DC Adapter used with Dell Inspiron 8600. No green light indicating power is getting to it from car cigarette lighter, and AC icon is not seen when plugged into the laptop (still shows battery icon). Can I break into this adapter and replace a fuse or something?
  • Dell Master
  • 4,806 Answers
There is nothing you can do appart from replace the car adaptor or check that the cigarette lighter is recieving power to the socket
Posted on Nov 24, 2008
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 12, 2010 | Dell Inspiron 1300 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
My dell inspiron 1420 dont charge. the indicator in the taskbar does not indicate that it is charging if it is plugged in
Either you got a faulty AC adapter or there is a problem with the DC power section of the Inspiron (or maybe the DC jack). Usually it's the adapter. You can check it with any commercial multimeter: it should give you 19V with internal positive. If it's broken, most Dell use the same adapter and it's easy to find cheap deals on eBay, for example.
Unfortunately, if it does work, and yet the notebook is NOT working if you take out the battery and plug the AC adapter only, you'll probably have to call Dell tech support.
Dec 05, 2009 | Dell Inspiron 1420 Laptop
My Dell Inspiron laptop won't power up. There are no lights AT ALL. It worked when I left for holiday. I have bought a new AC/DC power unit: just the same. The green light comes on when I plug the AC/DC...
If the light on the A/C adapter "goes out" when you connect it to the Laptop... then your motherboard is bad.
Your motherboard is "shorting out" the A/C adapter, in which case you will need a new motherboard.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dead inspiron 8600
take out the battery and use the AC.
if that power up the laptop. then the battery is draining the power source. if not, the laptop power citcuit need to be check out, which I think should be done a repair shop.
Dec 01, 2008 | Computers & Internet
Dell Inspiron 8600 Not Powering Up
have you checked all connections to the battery, make sure the battery terminals are free of cerrosion(rust&mold) make sure alll the power cables are intact. it does not sound like the power supply due to the fact that the light is coming on for a min or so.
May 11, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 6000 Notebook Logo
103 people viewed this question
Alun Cox
