Converter box remote control
1) RESET THE CODE again for remote contrl
2) Try again .
3) Clean the contacts batteries very well
4) Change the batteries by alkalines
5) Retight the springs contacts with pliers
6) Resolder the wires contacts.
7) Otherwise you must open the remote for clean, from dust, or oxide. or you must go to the repair shop.
God bless you
SOURCE: Haier / Celera TV & RCA Converter Box remote code
hi guys,
pgm-->tv code-->ok-->you are done
try this link for codes.
http://www.1800customersupport.com/productdocuments/DTA800_code.pdf
hope you got it.
Satya.
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
SOURCE: Universal Remote used to control Digital converter box
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
SOURCE: Remote control code for an APEX digital converter
If that code is not listed in the little booklet that comes with the remote control then it's probably not capable or controlling the APEX converter. Most of the universal remotes can't accommodate digital converter boxes. The only possibility is doing a search for the code manually as instructed in the booklet. I suspect you won't find anything that will help you out except getting the original control from the Manufacturer or replacing the entire box and you will get a new remote control with it.
This is a problem I have run into before, the universal remotes people just don't have access to the digital converter codes. They are proprietary and vary from model to model and brand.
Zashiban
SOURCE: Magnavox converter boxes. Remote controlls are
I need to find a Magnavox remote for my converter box. Help.
