Scambled picture Magnavox tv: MODEL #: RS2565 B802 CHASSIS #: 25D502-00AA COLOR: GOOD COLOR SOUND: GOOD SOUND PICTURE: PARTIALLY SCRAMBLED (PICTURE BENDS/WAVES,UN VIEWABLE) The picture is scrambled(wavy,unviewable) until you turn the set off! When the set is turned off,the sound does turn off,but the picture stays on and corrects itself just fine,10 to 15 seconds latter,the picture turns off when you hear the "click" made by the enternal relay.Any advice?
  • 3130 Answers
SOURCE: TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Posted on Sep 14, 2006
  • 36 Answers
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Posted on Jan 09, 2008
  • 3459 Answers
SOURCE: '42 Magnavox television won't show picture
I had the a similar issue. But on mine the first symptoms I had was that the screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no video but the power light was still on.
I gave up and called in a repair tech. He fixed my TV in less than 30 minutes . I put together a how to guide and parts kit to help others solve the same problem.  Not sure if it will work for you - my set never made the clicking sound - but it may be the same issue.
Posted on Jun 21, 2008
  • 125 Answers
SOURCE: LG CRT HDTV Dead no picture
if you have the b + acording the manual then you loose it
could be many things like the vert. circuit, the crt itself or
the flyback,
Posted on Aug 06, 2008
  • 905 Answers
SOURCE: TV turns off by itself
ok , first you will need to check the controls panel on the front board, take it out of there and make sure that the buttons are not being pushed on and check the sensor for a short or open also the contact switches are not making continuity(short) then also unplug the controls panel from the main board
and please give me a fixya rating so that i may continue to help you with this problem( anything other than a fixya rating hurts our rating as a fixya expert) that is if you belive that my help will be beneficial to you, thanks
Posted on Nov 09, 2008
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Screen scambles into pixels, no picture, no sound.
not kowing where on the planet you are its hard to comment but if you are trying to receive a digital then the aerial need to be outside clear of objects anologe signals will work better in loft spaces satellite wont work at all
Jan 17, 2010 | Televison & Video
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
you need the ssm panel. You can get a replacement panel for your model at the following link.Which is the correct board for your model it controls color, convergence and etc.
Apr 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
I had the same problem. Check for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
TV scrambles
Sounds like from what your describing, a horizontal sync problem and there are a few capacitors in this model that does cause that. If your not a tech this is something you should mess with as the way to trouble shoot this problem would be by using a scjhemetic, a isolation transformer and an ocilliscope. its a possiblity that you could also have a tune rproblem thats giving the sync separator circuit a weak sync pulse from the video its putting out. Good Luck
Jul 31, 2006 | Philips Magnavox MS2530C 25" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
