Question about Sony PlayStation 2 (PS2) Console
USB Connector Hi, Is it possible to connect a hard disk/flash drive to the USB connector slot within my PS2 and have the PS2 read from it? Would it be possible to store a movie/clip within a hard disk and have the PS2 console detect and play it? Appreciate a response Rajeev
  • Anonymous Mar 21, 2009
    how to connect usb hard driver to ps2 and play games install in it
  • akshay_849 Mar 22, 2009
    can we connect a pen pdrive to yhe usb hub in ps2?
  • 41 Answers
Not without modding your psp, its not really worth it
Posted on Nov 24, 2008
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
When i plug in my pc, it is not detected therefore I am unable to open the file
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Software Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Jan 01, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How to install 2 t hard drive in computer compaq
A 2Tb hard disk will be a SATA hard drive. If your PC Desktop does not have a SATA disk controller then your have a couple of options.
1. Insert a SATA controller card into the PCI expansion slot, mount the SATA hard drive inside the PC case and then connect the SATA hard drive to the controller (you will also need a 4 pin power to SATA adapter cable) and install the SATA controller driver.
2. The other option (and the easiest) is to purchase an external USB 2Tb hard drive. All you need to do is, plug it into the USB port of your computer and it will see it as an external storage device.
Oct 22, 2010 | Computers & Internet
What are the different parts of a motherboard?
The motherboard or PCB (Primary Circuit Board) is responsible for connecting all computer devices to the microprocessor. It supplies devices with power and allows the computer to react with them, Devices that can be used by connecting to the motherboard are: Storage devices, sound cards, graphic cards and hard disks.
Devices or components that are needed to make the computer work as it should, are inbuilt within the motherboard or can be connected to it using a socket or port. Listed below are sockets and ports that are available on the motherboard for connecting devices and , what that they are capable of doing.
PCI (Peripheral Component Interconnect) slot: Supports peripherals like sound cards, DVD decoders, and graphic accelerators with 32 bits at 33Mhz capabilities. There are usually anywhere from 1 to 6 PCI slots available on the motherboard.
AGP (Accelerated Graphic Port): This provides fast bus speed connectivity along with fast access to the main memory. It is designed for video cards that demand higher bandwidth.
Chipset-North Bridge: An integrated circuit that has special duties.
CPU (Central Processing Unit) socket: A socket specifically for connecting your computer processor.
DIMM (Double Inline Memory Module) slots, SIMM (Single Inline Memory Module) and RIMM: Different types of memory (RAM) can be installed into these slots.
Motherboard Battery: A battery compartment, which stores the battery used for storing data such as system date and time, when you shut down your system.
IDE Connector: Responsible for connecting the IDE cord used for hard disks, CD drives, and DVD drives.
Firewire header (IEEE 1394): A serial bus used to exchange digital and audio data with high performance abilities.
The following listed items are parts that are built within the motherboard with specific connective uses such as keyboards, mouse, and printers.
PS/2 Connectors: Each motherboard usually has 2 PS/2 connectors for the keyboard and the mouse.
USB (Universal Serial Bus) port: There are usually a couple of these ports located on each motherboard used for connecting pen drives and external hard drives, like Ipods or Mp3 players.
Parallel or (LPT) port: The place used to connect scanners and printers.
Game Port: The port to connect all gaming devices for example, a joystick.
Sound Card Connectors: Plug in your microphone or speakers here.
Display Connector: Connecting your monitor to the motherboard.
COM (Communication) port: The port designed to connect your mouse and modem.
Jun 18, 2010 | Intel Motherboard
Disk read error
kindly chek the drive connection make sure the cable is properly connected if possible then change the power connector of the hard disk.and boot the system in safe mode and go to command prompt and type chkdsk /r /f and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Removed hard drive from macbook (2.5', hitachi model hts541680l9sa00) and am trying to connect it to my EZQuest Monsoon Slim Firewire/USB 2 Hard Drives (i.e. portable 2.5 alum case) but just cant figure...
Your Hitachi is a SATA hard drive, EZQuest manufactures both a SATA and an EIDE model. Is your model the SATA one, or does it have a large connector with about forty holes on two rows (EIDE)?
If both are SATA, you should be able to see a SATA slot on the hard drive, such as this
http://bixnet.net/images/HDD25SATA-Connector.jpg
and a largish black with two "L" slots in it (possibly, the connector is divided in two "L" connectors) such as this
http://www.kustompcs.co.uk/acatalog/3852.jpg
Hope this helps, have a nice day
Jan 12, 2010 | EZQuest Monsoon Hard Drive
I want to read the files of my old Hard drive?
ok you have a pc. now, plug the IDE connector to your old hard disk and plug the power connector also. Now, you have 2 hard disks. Your old hard disk must be plugged into the secondary IDE slot. Dont touch anything with your original hard disk. Just add your old hard disk to your PC through the secondary IDE slot and using IDE cable. When your Windows OS opens, you will see a new Hard Drive when you open My Computer. It could be Drive E, F or G
Oct 09, 2009 | Maxtor Hard Drive
Connecting my external 320 to my laptop but its just flashes
Try a replacement USB cable first, and test the MyBook on a different computer, to ensure the fault is on the external storage unit.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
May 13, 2009 | Western Digital 320GB MyBook External USB...
External USB Drives No Longer Detected
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
CAN'T PUT BACK HARD DRIVE (TOSHIBA M35X-S161) LAPTOP COMPUTER
Is this a IDE or SATA drive?
Is the drive (or connector) possibly upside down?
Dec 08, 2008 | Toshiba Satellite M35X-S161 Notebook
Sony PlayStation 2 (PS2) Console Logo
108 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
