Question about Mitsubishi WD62628 62" Projection HDTV
No picture after changing lamp, tv will not power up.
In Oct. 2008 I replaced the lamp in my WD 62628. This morning I did not have a picture, but I had sound coming from my home theater ceiling speakers. My system, including my Dish PVR is controlled by by Logitech Harmony 880 controller. My TV and all components were purchased July 2006. I have a Monster (Signature series) HTS 5100 MK II Surge protector for all components.
I changed the lamp again. No difference, same issue. I looked at the lamp I removed, it looks fine.
I have also done a reset several times and have pushed the "on" button on the tv itself which does not turn on the tv either.
Any ideas what the issue may be? I've been following a CNET forum on problems w/Mitsubish tv's and see a lot of owners are also having problems w/their tv's also, but have not seen one similar to mine.
Thanks for any advice or info provided!
  • topheater Dec 28, 2008
    At times tv picture does not come on but sound does. After several resets and leaving tv off awhile it starts to work again. this is very annoying I just ordered a new blub but I don't believe this is the problem.
  • 934 Answers
Try bringing up the menu. If you can't I'd suspect the fmt board if you can suspect the dm module.
Bill
Posted on Dec 04, 2008
There is a switch that triggers when you put the vented cover back on the back of the tv. If cover is not on the tv will not come on...may be bad switch.
Posted on Oct 13, 2011
Our Mitsubishi WD-62628 screeb/picture will go black, you can still hear the audio. What is the problem??
Posted on May 06, 2011
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Mitsubishi WD-62628 power shuts off!
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
Oct 03, 2008 | Televison & Video
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi tv model wd-62628
It's most probable that you have a ballast issue, it might not have enough power to keep up with the new lamp. That's why you don't get any image.
Aug 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Sound no picture
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
453 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
