Question about Gateway CX2610 Notebook
Stopped turning on, charge light appears when plugged in...
I had to flip my house's main breaker switch a couple times while replacing an outlet in my kitchen and did not remember my Gateway cx2610 was charging.  I went to use my machine later on that day and noticed it was charging, but not running.  I tried to turn it on, but no response.  Any ideas?
    Scholar:
  • 70 Answers
Here in the UK there is a fuse in the power plug, I don't how it goes in the US, but if you have a fuse in the laptopcharger's plug try to change it to a new one.
If there's none in the plug than if the laptop was not switched off, but it was in standby mode (very common with vista) and the charger went dead, than the battery went out of juice and the windows switched off the laptop, in that case try to buy a new charger, or use a spare one if you have any and it should work if there's no bigger problem, bout you had to have a big power spike for that and that would have damaged the TV or something else in the house as well.
Posted on Nov 24, 2008
  • Gateway Master
  • 4,806 Answers
Try removing the battery and plug in AC power only and power up, sounds like you may have shorted the battery
regards
Breaker in garage flips after installing new 3 way switches and outlets
go back and check the wire colors on the devices that trip the breaker
Oct 21, 2013 | Electrical Supplies
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Gateway cx2610 laptop hd password protected cant locate cmos battery
These WEB sites may help you remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Dec 01, 2012 | Gateway CX2610 Notebook
We just recently moved, and when we plugged in our dryer at the new house, nothing comes on. I cant even get the screen to light up, almost like the power source is dead. I checked the breaker on the house...
-Try difference outlet. If it works then the first outlet you plug in has no power.
-You said you already check the breaker. it looks fine.
-Did you do any thing to the breaker or just look...?
-If the outlet that you want to use still has no power then how about try this:
-Open the breaker panel. Flip all breaker off, then flip all on one by one and check again. If you have power now then good. But still have no power then most likely the previous owner or renter disconnect the wires to that outlet from its connector. At the junction box or may be at the breaker.
Good luck
Mai
Jan 19, 2018 | Electrolux EIED55H Dryer
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
We're attempting to label circuit breakers in our home. One is currently labeled "WM" and it's not the washing machine. What might it be?
Hello
It could have been the washer at one time but the breakers got moved around over time. The washer should be on its own 20amp circuit. What size is the breaker? 20amp? 15amp? It is on the tip of the switch of the breaker. If it's a 20amp it should be for the kitchen or dining room outlets. It could also be for an air conditioner in the window. If it's a 15amp then it could be for lighting or other outlets other than the kitchen, dining room or ac outlet for window ac. That's just the basics. How old is the house? I've seen some really mixed up wiring in older houses. You could also buy a "Sperry" circiut breaker finder for about $50. It has a outlet plug that connects to an outlet and another handheld scanner that you scan the breakers with to find the correct breaker so that you can label it.
John
Aug 01, 2009 | LG WM-1832C Front Load Washer
Cannot find wireless switch for my Gateway cx2610
It probably is a small switch on the front or the sides of the computer. If there is not one, then it is Fn+something like F2.
Jun 12, 2009 | Gateway CX2610 Notebook
Not truning on
I would check your breakers again your oven breaker is a double one .. one of them may not be turned back on...
Apr 17, 2008 | Frigidaire FEF355 Electric Kitchen Range
Popping the Breaker
Ok, first a couple of things, you didnt mention if it popped the breaker when you were using the oven, burners, of both or if it does it as soon as you plug it in. If it does it as soon as you plug it in, you have a short in the back of the unit. you need to pull the back panel off and look to see if the broil or the back element wires were touching the the back panel. This is a common short. If it only does it when you are using both the burners and the oven, you might have a weak circuit breaker that needs to be replaced in your house. Unfortunately, age has little to do with it, I've gotten new breakers that didn't function correctly.
May 24, 2007 | Frigidaire FEF326 Electric Kitchen Range
Gateway CX2610 Notebook Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
