Question about Samsung YP-MT6X MP3 Player
Samsung YP-T6 memory problem
I have 1G memory in my MP3, and the other day, when I turn on the MP3, it just told me I have no free memory and then turn itself off. If I try to reformat the MP3 on the computer it would just freeze the computer instead... Not sure what happened. Can anyone help?
  • 4 more comments
  • Anonymous Jan 05, 2008
    computer installtion
  • sebbway Jan 08, 2008
    I put my mp3 on for heard my music, I got nothing in my mp3 and It indicate to my memory is full but I know is not. I check in the computer if I have something and all my song is present.
  • Anonymous Feb 04, 2008
    i can't make my mp3 no yyyyyyyyyyyyyyyyyyyy
  • Anonymous Jun 02, 2008
    MIMORI FILL
  • nokoredifour Jun 25, 2008
    i have a 512 mb samsung yp-t6 player . but when i restarted it said ihad no memory left and when i try to format my computer does not recognise the player.
    henry
  • suresh_India Aug 11, 2008
    I too had a same problem..You can solve it by using the User manual Compact disc which is provided by with the player. In that there ia an option for formatting the mp3 player. using that you can solve this.
To fix the "no free memory" problem, all you have to do is reinstall the program or try installing it on a different computer. Once installed again, the device is able to update properly. Cheers.
Posted on Mar 22, 2008
That's ridiculous! As long as the battery size is the same (i.e. AA or AAA) it shouldn't matter. Also, this is a flash-based MP3 player thus there is no hard drive. Although I am not 100% sure, the firmware (internal software or memory) of the MP3 player maybe screwed up. Follow the link below and download the newest firmware for your MP3 player and make sure you download and install the correct one as there are a few similar models (i.e. YP-T6 vs YP-MT6). Read and follow the instruction carefully and it should fix the problem if it is because of corrupted firmware/internal file-system. This hasn't happen to my Samsung YP-MT6Z 1GB MP3 player yet but this trick works everytime my Rio Forge MP3 players has internal memory problem. http://www.cczclan.com/yp-55download.asp
Posted on May 30, 2007
I am having the same problem on the Samsung YP-T6 and i think it is because i might have fried the harddrive by putting in a non-alkaline battery in it. its like trying to plug in a american plugin into a plugin in germany, you blow up the house...
Posted on Jan 26, 2007
Can i like upgrade my memory stick myself ?
I think you may have to buy a new memory card
Aug 29, 2012 | Samsung YP-K3 MP3 Player
My mp3 player is not turning off
please try to run superantispyware scan. it is free trial version
super antuvirus : http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
and http://siri.urz.free.fr/Fix/SmitfraudFix.exe
then
try to type DEVMGMT.MSC in run command
and delete all USB device from the device list.
then restart the system.
then replug the mp3 player.
Thanks
veeru
May 08, 2009 | Laser MVP-1G MP3 Player
Samsung YP-T6 MP3 player keeps turning off when system loads 100%
I have had the same problem several times. Each time I needed to flash the firmware. Go to Samsung.com support > download center > type in the model number (yp-mt6) click on firmware, and download the version that corresponds with your device. install the firmware updater on your computer, plug in your device. and flash the firmware. (this will erase ALL songs and settings so you will want to back those up first). After that its like brand new. Kepe the updater handy, I fixed this the first time, and it kept reoccuring every few months.
Apr 03, 2009 | Samsung YP-MT6X MP3 Player
Creative Muvo v100 1g desformated itselfe
No solution, flash memory damaged, if it has garantee, return it to the factory...and get a new one free...unlucky i found this web site too late and no gaantee for me....
DO NOT FALL ON SAME MUSTAKE! WATCH YOUR GARANTEE!
Feb 02, 2009 | Creative Labs Muvo V100 MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
I NEED HELP INSTALLING MY SANSA CLIP TO MY COMPUTER
lost my instruction for my 1g mp3 player and not sure how to add a memory card. can anyone help me with this. it is a thomson 1g mp3
Sep 23, 2008 | Audio Players & Recorders
It keeps switching itself off
it happened on my 6300 try removing your memory card (if any) then try turning in on..if that solves the problem then your memory card has a virus..try formatting them
Jul 10, 2008 | Nokia 6300 Cellular Phone
My computer does not recogcnise the mp3 player when plugged in
i would manually find the drivers and download them online. find the specific model drivers. hope that works.
Jun 28, 2008 | Laser MVP-1G MP3 Player
Samsung YP-MT6X MP3 Player Logo
1,104 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
