Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Cut cord my girl freind cut the cord on my washer none of the cord is sticking out how do i fix it can you send me info on how to fix the whirlpool gold washer thank you dan
  • 962 Answers
With the washer disconnected, remove the top panel. then remove the front panel until you see the motor where the cord used to go out. You will probably have to do some soldring if the cord can't be reattached. check where the power supply comes from and start from there. you will need to remove the old piece of cord and resolder the other part by splicing the cord and removing a piece of the rubber insulation.And resolder back on power supply.
Posted on Nov 24, 2008
Whirlpool Duet Washer Model # GHW9100LW1 is not spinning properly, leaving the clothes wet.
could be a couple of things ,none of them good! not easy to get this thing apart by your self and not cheap to fix.
Dec 15, 2017 | Whirlpool Washing Machines
All the lights on but not start
Door switch located above door latch R side is broken should stick out so when door closes the switch is engaged. Temp fix is toothpick cut half inch long then poke in hole. Until a switch can be replaced.
Oct 23, 2012 | Whirlpool GHW9100L Front Load Washer
Electric simoniz runs for a while than cuts off for awhile and st
Hello: Are you using and extension cord? You cannot, it will kill the motor. If this is not the problem it is the unloader valve sticking. This is quite a job to fix but can be done. Let me know.
Jul 01, 2009 | Honda Pressure Washer PSI 3000
How to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Apr 20, 2009 | Whirlpool LSR6232J Top Load Washer
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Steamer #410 has cord problem
u can send it back or u can fix it urself its a simple fix all u have to do is check the power cord going in u can cut about an inch n reattach it and it should work good luck
Nov 16, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
