Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 52 in DLP.
I have a Mitsubishi WD-52525 50 in. manuf date = 2004.
I experiece a power outage in the morning where I live, the TV was off, but when the power came back up I saw the green light blinking on the TV from the timer light. I'd unplug the TV from the outlet, also click on the reset button but nothing, zip, no luck!...
Please help!
Thanks in advance!
  • flyktmd Nov 24, 2008
    timer light blinks green. Neither unplugging ac cord nor hittting reset button helps.
  • bugsy4ever Nov 27, 2008
    Same problem here. I kept getting message that TV will shut down due to air flow blocked. (It isn't blocked, of course) Then it will shut down and timer will flash for about a minute and go off. Then TV will turn on again normally. Until now. Neither unplugging/plugging back in or System Reset button will turn set back on. Just the non stop flashing green Timer LED.
  • Mitsubishi Master
  • 8,617 Answers
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Posted on Nov 24, 2008
My Mitsubishi WD-82738 dlp tv turns off after a minute
You have a power supply issue that needs to be addressed.
Mar 04, 2016 | Mitsubishi WD-82738 DLP TV
Tv turns on works for awhile then shuts down
it seems cooling problem check if fan is working or not
and check the english user guide
http://www.manuals365.com/swf/mitsubishi/wd-62327.html?page=50
Mar 17, 2015 | Mitsubishi Wd-52327 52" 1080i Hd Dlp...
73 inch tv speakers are off how do you turn them on
Go to menu and click on sound on this click to see if speakers are turned on if not click on if that doesnt work try the try the return to factory settings..
Jul 14, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi Televison & Video
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a WD-65737 Mitsubishi DLP TV . Last night it was working great and then this morning it didnt come on . I mean its like it isnt getting any power . The green light isnt even coming on . Please help
iI just had the sMe isuue. your tv needs a system upgrade. Contact Mitaubishi and they will email the upgrade link. You will need Aa thumb dri.ve upto 4gigs to downlaod...ensure its empty. They directions will guide u. thru.
Sep 30, 2010 | Mitsubishi WD65737 65" DLP TV
Steady blink green light, WILL NOT RESET!
Thats a common problem with that model which is the V26 chassis. The V26 DM repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the replacement capacitors and the CD with detailed instructions its 35.99 which includes shipping
Oct 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Aug 19, 2009 | Mitsubishi WD73727 73" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
348 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
