Question about Refrigerators
MY LG refrigerator model # lfc25760sb stopped working
Lights are on inside, but not cooling. I've tried unplugging it. turning breaker off and on. Resetting the controls. NOt sure what else to do...
  • ericcandelas Nov 26, 2008
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
  • 1122 Answers
SOURCE: refrigerators not cooling
no reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Posted on Sep 22, 2008
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
How to replace lights on refrigerator LFC25760SB
In the LG bottom freezer refrigerator (model LFC25760SB), the light bulb covers inside the refrigerator and freezer compartments are attached using friction-fit clips.
It will be safest to unplug the unit, or shut off the circuit breaker. You may also need to remove Items, including the top 1 or 2 shelves.
Push the front of the cover gently toward the back of the refrigerator; LG's instructions show a screwdriver, but I would use something more flexible like an expired credit card or emty gift card. Swing the cover down to unhook the clips at the back.
Be careful with the bulbs, as they can get very hot, particularly if it takes some time to clear the way to the cover and get it off. I would close the door and wait a few minutes to let the bulbs cool off before removing them.
LG has a downloadable manual on their website that shows the procedure and gives the bulb specs (60 watt appliance type). LG LFC25760SB Support Manuals Warranty More LG
Feb 28, 2018 | Refrigerators
Dometic R V refigerator model RM2611. Will not cool on gas or electric. The unit that has the filler plug on the end(Looks like a thermos bottle on its side) gurgles when supposed to operate. Unit...
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 30, 2008 | Refrigerators
GE Artica PSS25NGMD Side by Side stopped cooling
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. If it does, the relay is bad and will need to be replaced. Here is that part to order.
Here is the overload relay that should be replaced also.
Is you pull the relay and it does not rattle, post back the results to me.
Here is a video to help you out.
Feb 09, 2013 | Refrigerators
Sounds dangerous and a fire hazard. Unplug it until you find the fault with the unit or replace the fridge.
Oct 11, 2017 | LG Refrigerators
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
The light bulbs inside my LFC25760SB are staying on constantly, even with the doors closed. In addition to warming the food, this has also caused melting of the plastic parts surrounding the bulbs. I can...
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Dec 20, 2009 | LG Refrigerators
LG LFC25760SB french door light off but hot
try to replace the bulb/ door switch
Nov 13, 2009 | Refrigerators
Refrigerator doesn't stay on.
sounds like when you moved it you created an air lock, when moving fridges etc. should always leave for 24 hrs to settle before plugging in.... , no guarantee but try laying it down and leaving overnight then stand it up again and leave for at least 24 hrs for the refrigerant to try and sort itself out. UNPLUGGED from mains of course... good luck
May 02, 2017 | LG LFX25960ST Stainless Steel French Door...
Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
The control board relay switch for the light bulb stuck in the on position and needs to be replaced along with the light cover and housing.  There is also a replacement light harness that has a high limit switch to shut off the lights if this happens again.  LG knows about this problem and if you call LG customer service, they will grant a one time warranty extension to take care of this problem.
Jun 09, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
385 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
