Question about Pioneer AVH-P7600DVD Car DVD Player
Pioneer AVHP7500dvd I got a pioneer AVHP7500dvd from a friend where the screen and motor unit had driven out of the case. How can I get it back in? How can I get the motors to reverse? Is it possible? Thanks for your help!
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: will not read disc & lots of motor noise
Your problem is a common one. The spindle motor is going bad or is bad, and/or you need to clean the laser lens. The only way to fix this would be to take out the unit and hook it up to a test harness. If you do not have a test harness you will need to seek out an authorized repair depot to do this for you. good Luck Ps Please dont forget to rate this thread.
Posted on Oct 23, 2006
This unit motorhome with a avhx2700 radio unit. we have a very distorted navigation screen got any suggestions
[PDF]AVIC-U260 - Pioneer
https://www.pioneerelectronics.com/.../AVIC-U260+O... Pioneer CorporationPIONEER AVIC-U260 - for Canada 8. - END USER .... ing or distortion and, most importantly, with- ...... After a short pause, the navigation screen ap- pears.
AVH-X5700BHS - DVD Receiver with 7" Motorized ... - Pioneer
www.pioneerelectronics.com/.../AVH-X5700BHS
Pioneer CorporationFeb 16, 2015 - For more information, visit pioneerelectronics.com/AppRadioOne ....Easily upgrade to navigation with the addition of the AVIC-U260 add-on ...
GPS Navigation ' Pioneer Electronics USA
www.pioneerelectronics.com/PUSA/.../GPS-Navigati...
Pioneer CorporationCar Navigation Systems products with built in bluetooth handsfree technology. Includes dvd gps navigation: in-dash and portable. ... AVIC FEEDS App.
Jan 13, 2016 | Pioneer AVIC-U260 Add-on Navigation Unit...
Can not open cassette player door
There are typically cam belts that become lose after some time that allow the deck to get stuck in a mode that locks the door closed such as play mode. Rotating the pulley that is driven by the motor will release the tape but that is just to release the tape- you need a new belt in the unit and some cleaning and lubrication to make it working again.
Oct 18, 2012 | Audio Players & Recorders
Hello My turntable do not spin
This turntable is a belt driven type. The belt wraps around the underside of the platter and the drive motor spindle. If the belt has slipped off, broken or is so old that it is slipping - the platter will not turn. Usually you can remove the rubber cover on the top of the platter to use access openings beneath to put the belt back on.
The turntable product brochure, owner's manual and related info is available from Pioneer, here.
I hope this helps!
Dec 03, 2010 | Pioneer PL-990 Turntable
My pioneer deck screen goes blank at start up after the splash screen
The problem is inside the unit. You have to remove it and send it in so that pioneer can reinstall the software for your unit.
Sep 04, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
Screen wont go in on my pioneer avh-p5700
OK,
First of all there could be a problem with your slide in mechanism. This could be a factory defect or it could be that the person who installed the Avh P-5700 didnt install the deck sleeve in correctly. Alot of times we the installers face an issue trying to fit a head unit or slide in tv unit like yours with space, unfortunately some vehicles have a very tight or minimal slide in space for aftermarket radios or units like the AVH. The problem that we face is that when A unit like yours fits in forcefully due to space restrictions it will apply pressure on the units slide mechanism and the protection sensor will push the screen back out because it does not properly fit in , these units are so sophisticated that the slightest pressure will make the screen slide back out or not accept the screen in at all. Try to readjust your sleeve and the space around the sleeve if not my friend you have to get custom, which could be an issue if you dont have the skill to perform these tasks.
Good luck my friend,
Lex...
May 23, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Lock control program after open cover lid of Pioneer PDP434 PG
If you had power this set on with the back off it will not work without closing the switch again and entering serv mode and reactvating . Call pioneer customer serv to get info to reset the unit. Must have pioneer remote to do this reset.
Aug 29, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer deh-p840mp weird concern
this is a problem that is caused by the ribbon cable that connects the two faces going bad - you can find repair kits for this unit on ebay.. just search DEH-P840MP and you will find "ribbon kits" or repair kits. They are usually about 15 dollars.
Jan 14, 2009 | Pioneer DEH-P840MP CD Player
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Pioneer DEH-9800BT Cannot keep Blackberry connected to receiver, it will see the phone, but will not stay connected
This is a common problem with the first run of bluetooth enabled Pioneer head units. I spoke to a friend of mine at Pioneer Tech support and he's informed me that there isn't a fix for it. Sorry you may just be out of luck.
Jul 17, 2008 | Pioneer Car Audio & Video
Pioneer AVH-P7600DVD Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
