Question about Motorola Mobility H700 Wireless Headset
Need motorola h700 head set
I need instructions how to set up this motorola h700 head set head set
  • Jason Bornheimer May 11, 2010
    What exactly do you need to set up? is it pairing the device to another one or changing the settings???
    Champion:
  • 279 Answers
  • 60 Answers
Hi, you should be able to locate a manual at the following website....  http://www.manualsonline.com/
I hope this helps :)
Posted on Sep 18, 2009
    Problem Solver:
  • 5 Answers
    Scholar:
  • 65 Answers
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Posted on Jul 30, 2009
4 Suggested Answers
SOURCE: help! I've no idea!
fold the boom up, push and hold down the central button until it turns violet, open the boom and then let up on the button. The central button should stay violet without blinking. Then go through the pairing routine on your phone.
Posted on Mar 04, 2007
  • 35 Answers
SOURCE: Motorola H700
First, you will need to put the H700 into pairing mode. Look at the last digit in the part number for your headset (there are 3 versions). If it "A" or "B", do the following... 1. Starting with the headset powered off (flip closed), hold down the Call button for 1 to 5 seconds until the light is steadily lit in purple. 2. With the light steadily lit, flip out the boom. The light should remain steadily lit in purple. If the light is flashing, or if the light starts flashing anytime before completing the steps below, the headset is not in pairing mode, and these steps will need to be repeated. If you part number ends in a "C", do the following... If the headset has never been paired with another device, simply open the headset boom. The indicator light becomes steadily lit in purple. If the headset has previously been paired with other devices, first ensure those devices are turned off. Then open the headset boom and the indicator light flashes in blue. After about 5 seconds, the indicator light becomes steadily lit in purple. And finally, you will have to follow these instructions on you A900... 1. While in standby mode, press the Menu/OK button 2. Select Tools (9) 3. Select Bluetooth® (4) 4. Highlight Yes, using the navigation keys, on the Enable Bluetooth® prompt 5. Press the Menu OK button to enable Bluetooth® 6. Select Bluetooth® (4) 7. Press the left soft key for Add New 8. Highlight Search, using the navigation keys 9. Press the Menu/OK button to begin search for new device 10. Highlight the desired Bluetooth device, using the navigation keys 11. Press the left soft key for Add to List 12. Enter Passkey "0000" press the Menu/OK button, you will get a brief message stating pairing 13. Press the left soft key for Done 14. At the Trusted Devices screen, press the left soft key for Connect 15. You will get a brief message stating connecting 16. After being connected you will return to the Bluetooth® Trusted Devices screen Hope this helps. Good luck
Posted on Jun 30, 2007
SOURCE: motorola blue tooth h700 set up
Solution 2 did the trick for me. Once I followed the instructions I was prompted for the passkey and I entered 0000, my ear piece finally works again! Thanks you!
Posted on Mar 30, 2008
How do I pair motorola h700 with motorola defy?
Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility H700 Wireless Headset
H700 charges fine, dies fast
You need to Change its battery For Your Head Set . Only solution is battery Change.
Mar 15, 2008 | Motorola Mobility H700 Wireless Headset
My H700 Motorola Bluetooth Headset
i just want to know how to get it to work in the first place... got a new phone and need to set it up but i lost my directions. how do i just get it to work
Oct 01, 2008 | Motorola Mobility H700 Wireless Headset
Won't detect Motorola H700
Hi David, I want you to go to this link for your nokia E65. Click the link.
http://europe.nokia.com/link?cid=PLAIN_TEXT_119729
On the left side of the page click Demos
When the demo window opens click, Select Demos button.
Scroll through the list until you see Sending Via bluetooth.
Follow the interactive instruction to connect to your H700.
You'll need to set your H700 into pairing mode when searching for the bluetooth H700.
It might be a good idea to book mark the main page.
Good Luck! Take your time.
Mike
Apr 04, 2008 | Motorola Mobility H700 Wireless Headset
Need a passkey lost it
The problem you are having with your H700 is not the passkey. "0000" is correct. The problem is the pairing process. I just paired mine after reading this with my blackberry curve.
1. Close the H700.
2. Hold the big button down until you see a lavender light.
3. Open the H700 while still holding the button down.
4. At this point it is ready to be paired. If the light changes color, the H700 has timed out waiting to be paired and you will have to do steps 1 thru 3 again.
5. With the lavender light on the H700 go through the pairing procedure on the blackberry.
Mar 21, 2008 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Help! I've no idea!
Feb 24, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
385 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
