Question about Microsoft Windows Vista Ultimate Edition
WindowsXP not loading after installing Windows Vista Demo Version
My system is running in Windows XP. I installed Windows Vista Demo Version. After installing, system is not loading Windows XP and its not working at all.
What is the best solution to remove Vista from my system?
I have some important files in my C drive. Is there any way to avoid formatting C drive ? And also tell me how to take backup at this situation.
Thanks,
Abbas.
  • Ali Abbas Nov 24, 2008
    well its indeed on dual boot n not on the same drive . XP is kept at C: drive n vista demo at E: drive .
  • 3 Answers
Try buying a new hard drive(hdd) installing xp on it disconnecting the old hard drive and making this primary boot disk in bios by going into setup then once installed close down windows insert the old hdd with the new one and set the bios to boot that hdd 2nd or not at all.
then u can try accessing the old hdd with the new hdd so you can back up your stuff then you can try stuff to fix your old hdd boot problem
(PLEASE SOMEONE DOUBLE CHECK THIS IS PROPER PROCEDURE AS I AM NOT A PROFESSIONION)
Posted on Dec 21, 2008
  • nzsimran Dec 22, 2008
    yeah my friend had a problem with his windows he managed to save all this stuff on a seperate hard drive so it can work i would get more details but he is over sea at the moment. he said he installed window on a seperate hard drive then access the error hard drive through my computer. also in bios i think you can stop the pc from booting from both drives so try and make it only boot from C or from E drive not both this may be done via accessing the bios setup (press delete BUTTON on bios loading page) then go to the boot tab. and then you can configure your which HDD has priority by pressing +/- and changing the order on the list.
    this should hopfully allow you to start xp or vista and then uninstall the OS that you want (prob.. VISTA) this may also allow you to backup you documents.
    IF THIS DOESNT WORK then try my previous comment about installing a new OS on a new hard drive to back up your documents other than that i can't help you any more hope you can fix the problem as i have two computers that failed me in two days and know the hassel of trying to fix them
    GOOD LUCK
    Simran
    Problem Solver:
  • 5 Answers
You need to get rid of the Vista Demo, and reload xp. You need to keep one or the other I think, you can't keep both operating systems on the same drive. What were you thinking?
Did you install the vista demo as a dual boot setup? Doesn't sound like it.
I hope someone can help you, I can't.
Posted on Nov 24, 2008
I recently purchased a new computer (HP/Windows 7) and am having difficulty loading my copy of PDFCreate!3. The error message is: "AddPrintDriver Cause of Failure - 2". Is this version of...
hi,
it does appear that even create 4 didn't have windows 7 support. You may try installing and then changing to windowsxp compatible mode by right clicking the icon and selecting properties and the compatibility tab then place a check in "run this program in compatibility mode" and choose windopws xp. and or install virtual PC with windowsxp compatible then install and run your older software in a virtual machine.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 08, 2011 | Computers & Internet
I can't install Bernina Version 4 on my VISTA Operating system PC
As far as I know, Bernina version doesn't work on Windows Vista, you have to upgrade to the next Bernina Designer version which is Vista compatible.
Oct 01, 2009 | Bernina Artista 180
Vista
yes you can install vista....................without lossing your data.......
If you are running windows xp then don't install the vista where you have installed xp...........just installed the window vista in other drive
If your system is running in vista only.......then u can install the vista on that drive this will not lose your data
Aug 24, 2009 | Microsoft Windows? Vista Home Premium...
ABOUT OS...
No it is not if Vista is already loaded. In order for it to work and have a dual-boot, the earlier OS must be loaded first. So, first you must have Windows XP; then you can load Windows Vista; however it does not work the other way around. So if you wanted to have both, you would have to wipe your hard drive clean, load Windows XP, then load Windows Vista....Good Luck.
Apr 09, 2009 | Acer Computers & Internet
Upgrading the OS Windows XP not possible
Upgrading from OS Windows XP:
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
NOTE:
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
 i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
WindowsXP professional, start up
This needs some understanding of OS only. Don't worry.
Now, coming to ur first problem... u can change the bootup xp options by modifying the c:\boot.ini (be careful too...and u r right, it will not slow down ur pc)
reg. the bootup disk problem, ... u may need to create a bootable CD for installation... u may get the 'bootstrap' CD image from internet (but, r u having a licensed version???)
Have a nice day
I hope, my suggestion was helpful
Mar 15, 2008 | Microsoft Windows XP Professional
Change of os
it is not possible to upload xp when vista has already been installed.
if you want xp & vista both in your system
remove vista
install xp
& later install vista .
it is not possible to upload a olderversion(xp) when you have newer version(vista)
you can download windows xp from this link
http://www.soft32.com/download_992.html
Dec 18, 2007 | Microsoft Windows Vista Ultimate Edition
Windows vista ultimate problems
It needs Microsoft office Key,
If your Office is not geniune you can get the key at:
http://www.seriall.com
If it was a demo disk, then why did you install it on your full version of windows???
Please rate if satisfied!
Dec 17, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
