Deleting old Alarm notifications
Having put alarm notices in the phone they remain there forever! No means of deleting them, alsowith Recurrence if you tick Once only, you cannot then select a day. Frustrating!
Do you really think I am that dumb that I will tell you how I fixed this problem so that you can make money out of the information? I am not as stupid as you seem to think.
Posted on Nov 25, 2008
Alarm on notification bar
If you open the clock app and click on the alarm page, you should see all the alarms you have created, if any of the little alarm icons next to them are green it means that that alarm is enabled, tap the icon to turn off the alarm, this should make it go away.
Jan 17, 2016 | Samsung Galaxy S5
Dictioary i need to turn off
You can go to message settings or the options in message and look for dictionary or T9 and turn T9 off.
If you want the alarm to ring each morning you can go to clock or alarm and set a particular time and set the repetition to everyday or weekly as you desire. You can also cancel the alarm simply by deleting or removing the alarm time that you have set which will be given in the options
Sep 17, 2012 | Samsung Galaxy Note - 16gb - Black...
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
Exclamation point
That's the notification icon. It indicates that you've "received 2 or more different types of notifications: Voice Missed Calls / Schedule / Call Alarm / Alarm Clock".
Check your Missed Alerts on the phone menu, your alarm clock settings in menu > tools and failing that, try going back through your calendar to see if you've missed any meetings or something there.
Jul 15, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Deleting alarm setting
bottom of the screen it will give you three options
(EXIT) (a symbol looking like four lines) (Disable/Enable)
High light the alarm thatyou wish to delete and press the middle button this gives you the options NEW, EDIT, DELETE, DELETE ALL
hittng delete will delete the highlighted alarm :)
Nov 14, 2007 | Motorola Mobility RAZR V3
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
Duplicate alarms
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Sep 14, 2005 | HP Jornada 548 Pocket PC
"No Time" calendar events stop synchronizing with Outlook
Try to Run this command
Start > Run > Outlook /cleanreminders
Sep 11, 2005 | Palm Treo 650 Handheld
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
