Question about Car Audio & Video
Jbl 6-disc changer toyota sequoia cd not displaying
I had the err3 message on the player when changing to the cd and was told to try and disconnect battery for 30 minutes to see if that would correct the problem. I did that and then when I turned the radio back on the system will not even change over to the cd now. Someone else said that it might be some sort of security setting but I am not sure.
  • Anonymous Jan 13, 2009
    similar problem with my jbl disc player 06 Rav
    the dealer told me minimun of $200 to fix,,,or 400-500 to replace.
    was not surprised when I call with the problem,,,first showed Err 3
    had a technician take unit out,,,remove my discs and then when they put it back it doesn't load
  • ShadyJake Mar 10, 2009
    2000 Toyota Tundra. Have 6 clean library audio discs loaded. Won't skip to next disc (#2) or go back to (#1). None will eject. Anyone know a trick to get the cd's out?
SOURCE: eclipse CD 8443 Secuirty Help
check this out... http://www.crutchfield.com/S-fFrcKywotzD/support/faq.html I have the same problem.
Posted on Sep 22, 2007
SOURCE: jbl radio in toyota sequoia
If I unplug all the wires from the CD player won't the security system lock up my stereo system? Which means that I have to go to a dealer to get the code from them.
Posted on Nov 01, 2008
SOURCE: Cd player in a 2002 acura tl
stuck CD in 6 disk player
Posted on Dec 27, 2008
SOURCE: 2005 dodge caravan rbq am-fm radio w/6 disc cd changer
Contacted local dodge dealer about my in dash 6-disc changer problem. Chrysler seems to have an "exchange" program. They will remove your existing radio, install a "factory reconditioned" unit and send yours in to be repaired and sold to someone else. The dealer told me that my CD's would EVENTUALLY be returned to me from Chrysler. The cost I was given was $265 plus sales tax for the exchange unit, and the labor to remove and reinstall. He said about a half hour labor. Compare this to the $604 for a factory new unit. Hope this helps everyone with this problem. I was told by the Service advisor that it is common for this problem.
Posted on Jan 30, 2009
  • 59 Answers
SOURCE: 6-Disc CD Changer is not working
Unfortunately most times with these 6-disc systems once it quits working it is usually time for a new unit. The manufacturers all reccomend reprogramming the radio, but this rarely does anything other than waste your time and money. Go for the new radio.
Posted on Mar 15, 2009
How to change a sparkplug on a toyota avalon 2007
This video should help. Believe it's the same engine you have:
Oct 09, 2015 | JBL 2005 2006 2007 07 Toyota Avalon Radio...
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
I have a toyota sequoia jbl 2001 6 disc changer and would like to find where i can get a replacement?
check here -> http://motors.shop.ebay.com/__?_from=R40&_trksid=p3841.m39.l1313&_nkw=6%20disc%20changer&_sacat=&rvr_id=219875829958&MT_ID=335&crlp=1274602876_9887&tt_encode=raw&geo_id=491&keyword=6+disc+changer&adgroup_id=776835316
Mar 22, 2011 | 2001 Toyota Sequoia
Error 3 on my 6 disc CD changer The manual says to eject and re-insert disc, but the player won't eject or play or change discs. What is the fix?
try disconnecting power to the radio for an hour or so. usually it is best to disconnect the battery overnight to reset the microprocessors.
Feb 28, 2011 | JBL MCDC100 6-Disc CD Changer
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
I have a 1999 Lexus LX470 with a Nakamichi audio system with a 6 cd changer in the dash. The cd's will not eject and the screen says error. What can I do about this?
I feel your pain......and did extensive research on the internet.....Google "LX470, CD, err3" or "Nakamichi, CD, err3".
Take a look at this excellent explanation of how to dismantle and remove the head unit and retreive the jammed discs. I have used it and fished out three discs, but the CD Player still shows ERR3. An hour of work, so be prepared.
http://www.celiamania.com/wordpress/?p=135
This is a site that provides repair services once you get the head unit out. http://www.carstereohelp.com/lexus.htm
"Six CD changer, Err message in display, will not play CD's, will not eject or accept CD's. Before repair, disconnect one of the car battery terminals for several minutes. This acts as a reset and may bring the changer back to working conditions. Otherwise, repair rate $385."
The Lexus dealer wants $750 to replace with a refurbished unit. Don't go down that route. Read these nightmare stories.
http://us.lexusownersclub.com/forums/index.php?showtopic=2346
http://us.lexusownersclub.com/forums/index.php?showtopic=38123
http://www.clublexus.com/forums/showthread.php?t=28371
http://www.clublexus.com/forums/showthread.php?t=50142
Don't buy a stray unit off of ebay, it is probably jammed or broken with the ERR3 meesage too!
If the home repair method doesn't work, then it will be better to just upgrade to a new head unit. I am buying a Jensen VM9215HD to get a multimedia system with all the trimmings and full iPod control for $460. Available on ebay or online stores. I'll install the unit myself, but you can get the unit and the job done at a local auto sound store for under $1000.
Good luck,
Arthur
1999 LX470 97,500 miles, ERR3 CD player
Aug 09, 2008 | Nakamichi Audio Players & Recorders
JBL Error 1
Error one is unique to the disc being inserted into the player.
According to the service manual, this is the exact statement:
Err 1 appears on the display:
This indicates that the disc is dirty, scratched, damaged, incorrect (as in a "burnt" disc), or has been inserted upside down. Clean the disc or insert it correctly.
Toyota CD players are very sesnitive, and the svc manual specifically mentions not to use anything other than "store-bought" CDs.
Jun 03, 2008 | 2001 Toyota Sequoia
Car Audio & Video Logo
739 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
