Question about HP Computers & Internet
How do I remove the dvd drive in an hp 3300t?
    President:
  • HP Master
  • 1,314 Answers
The upgrade manual can be found here. Refer to the section on removing the optical drive.
Thanks and please take a moment to rate as fixya.
Posted on Nov 24, 2008
    Novelist:
    Scholar:
  • 151 Answers
Spyware and adware are both softwares that came from publishers who intentionally sent these malicious softwares in your computer when you install free internet software download . They are hidden inside the install packages without your knowledge and they are very difficult to discover. These spyware and malware sneaks and spy on your internet activities, your internet habits and then overwhelm you with annoying advertisement popups.
Posted on Feb 22, 2012
    Sergeant:
  • 177 Answers
The manual for your pc can be found at http://h10032.www1.hp.com/ctg/Manual/c00877796.pdf.
In the manual there is a section named
Removing and Replacing an Optical Disc Drive.
Follow the instructions, and will will be able to remove the dvd drive.
How does one remove and replace the dvd drive in the HP Omni all in one 120-1124?
Hi Belle, for more information about your question please visit the website below. Good luck and have a nice day.
HP Omni 120 1124 Desktop PC Video Tutorials
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 25, 2015 | HP Omni 120-1124 All-in-One Desktop 1.65...
How to remove dvd drive
Search HP Pavilion dv6000z Besides a simple search HP offers supper easy removal on some models, including this one.
There is a video.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00816400&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3224052
Nov 24, 2012 | HP Pavilion dv6000z Notebook
Whenever i put a dvd/cd in my hp probook 4510s and try to open it, it insteads ejects
Remove the Power Cord, Remove the Battery, then close the lid and turn the laptop over and remove the one screw that holds the dvd drive in place on the bottom of the laptop. Remove the Dvd Drive and in about 20 seconds put it back in and Try rebooting to see if it solves the problem.
Your dvd drive might be defective and needs to be replaced. You can find one on ebay. Just put HP Probook 4510s DvD drive in the search.
Once you take the dvd drive out you can also search on the model of the dvd drive. The model will be listed on the dvd drive.
May 12, 2012 | HP ProBook 4510s Notebook
How do I get it out?
Turn off the computer and remove the power plug.
Open up the computer case by removing the phillips screws holding on the side panel. You should see the back of the dvd drive with two connectors in it. Remove the phillips screws holding the drive. Remove the connectors from the back. Pull the drive out of its cage/mount. Voila, a removed dvd drive.
Mar 08, 2011 | HP DVD1260i DVDRAM Burner
I want to remove my dvd cd re-writer drive from my hp compaq nc6220 and replace with dvd re-writer drive but need instructions
there two screws on bottom case below the dvd drive, who atach the drive steady, take this out and pull the drive out carefully, normaly use a flat small screwdrive, change it check for new one has the same screw holes positions
Jul 15, 2010 | HP Compaq nc6220 Notebook
I need to know how to remove a DVD drive for a HP lap top.
If your HP Pavilion DV6000 series laptop computer has a bad DVD drive, use the following steps to replace the drive
Purchase a new DVD drive to replace the old HP drive. You can use any slim DVD drive with a 50-pin ATAPI IDE Interface Connector. You will probably want a DVD burner since the original drive was capable of burning DVDs. The drive I used to replace the HP drive is a LG Black IDE Super-multi Slim Notebook DVD Rewriter - OEM version.
Unplug the power cord from your HP laptop. Remove the laptop battery from the back of the computer. This will eliminate the chance of power damage to your computer
Ground yourself by touching a metal object or touch your screwdriver on the ground while touching part of the metal. Unscrew the DVD drive screw circled in the Step 2 photo. Using a small Phillips head screwdriver turn the screw counter-clockwise until it is completely loosened. You may need to flip the computer over to get the screw to fall out. Put the screw in a safe location for later.
Put a small pointed tip object (a paper clip will also work) into the drive release hole on the face of the DVD drive. Use the hole to pull the drive out from the laptop body.
Remove the mounting bracket from the old DVD drive. There are two small Phillips head screws that need to be removed by turning them counterclockwise. Match the bracket up with the holes on the side opposite of the connection port. Using the two screws you just removed, secure the mounting bracket to the new DVD drive by tightening them in the clockwise direction.
Remove the original HP DVD drive face plate from the old drive. It can be removed by working it back and forth to loosen the faceplate. Once it is loose you should be able to pull the faceplate off.
Do the same for the new drive. Once the DVD faceplate is off, match the tabs of the original HP faceplate up and press in until it clicks into place
The new drive is now ready to install into the HP DV6000 series laptop. There is no need to hook up IDE cables and power cables. The new drive can simply be slid into the HP laptop.
Find the screw from Step 3. Make sure the DVD drive is pressed in all the way. Install the small Phillips head screw in the back of the laptop and tighten by turning clockwise.
Jun 19, 2010 | HP Pavilion dv6000z Notebook
Help with hookup
I am assuming you are driving a sub-woofer. Run the amp bridged at 4 ohms. So a DVC(dual voice coil) 8 ohm sub with voice coils wired in parallel would give you a 4 ohm load. Just make sure the sub can handle at least 300 Watts Peak.
Dec 17, 2009 | Pioneer GM-3300T Car Amp
Can't remove dvd drive (hp pavilion dv4000)
I think he meant reinstall the device driver not the actual device. Doing it to the actual device wont accomplish much but take some time. As for the driver go to this website: Click Here
Then download and run the fix it program there
Once you have run it restart the machine
You may have to do it twice before it works
May 29, 2009 | HP Pavilion dv4000 Notebook
Graphics card for HP slimline 3300t PC
troubles and tribulations of the compaq approach to board level expansion bus cards..been like that for millenia...
what kind of monitors you using?
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
