Question about Dishwashers
Inlet/Drain light flashes on Miele model G 641 SC PLUS
  • 1 more comment
  • nqbrownie Nov 24, 2008
    I probably should have given more details but I was so frustrated at the time I made the initial post.
    This has been an on/off problem for about 6 months. I have previously checked the drains and the pump. When I received the initial answer, I put the machine on again to wash. Everything went through perfectly. It leads me to think it is some electronic problem inside the machine.
    I have not tried it again but there is every chance it will get to the middle of the wash cycle, having gone through the rinse cycle and then stall with the Inlet/Drain light flashing and making e=regular attempts about every 90 seconds to resume washing.
    I am stumped.
  • nqbrownie Nov 28, 2008
    The solutions offered have not helped. Before the second idea was received, I used the machine again and it went right through the cycle - Universal Plus.
    I used it again. The machine drained what was inside in about 20 seconds, refilled in a minute and washed for 20 minutes. Then it stopped and did nothing further for 1 hr 20 minutes when the Inlet/Drain light began flashing.
    Sorry but I am no further advanced.
    nqbrownie
  • nqbrownie Dec 02, 2008
    I believe there is no blocking problem.
    Before getting a second answer from you (which has apparently been deleted), I had rub the machine again. Everything went through to a normal conclusion.
    Then, I tried it again. When first started, it emptied for about 20 seconds. Then it filled in a minute/ I then washed, including the emptyong of the detergent tray. The wash went for 20 minutes and stopped. Nothing happened for 1 hour and 20 minutes. Then, the Inlet/Drain light began flashing I lft it for 20 minutes during which nothing happened.
    I re-started the wash. It emptied and refilled and did the same things as just outlined.
    The water pump appears to work. The Inlet valve appears to work. There seems to be something wrong in the electronics of some switch within the machine.
    This has been an intermittent problem for over 6 months. I called in a serviceman about 4 months ago and, as so often happens, it worked when he was here. Then, he charged me $85 for telling me that!
    Any ideas on what to try would be appreciated.
    mqbrownie.
    President:
  • 2,110 Answers
Check that the stopcock is opened fully or whether the water inlet hose is kinked. Clean the fluff filter and drain pump as described in the operating instructions. If several indicator lights flash simultaneously and/or an alarm sounds, please contact our Service Department.
Posted on Dec 02, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The issue is an intermittent inlet/drain fault. Since the same indicator light represent a problem for either or both, then first order would be to determine which is really at fault and then why intermittently. Suggested procedures would be:
  • manually add water prior to powering on the machine to wash. This may have to be done several times and extend over some period;
  • if problem resurfaces at any time even with the added water, then it is not an inlet problem but a drainage problem;
  • if it is a drainage problem, then it would be the drain pump acting up. This is specially true if the dishwasher is not regularly used;
  • if problem does not repeat when water is regularly added, then it is the inlet system. Foremost to check/replace would be the inlet valve. In some instances, it could be inlet filters blocking the flow of water and in some incidents, it is just that the water pressure is not high enough to fill the dishwasher on a specified time.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 30, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 135 Answers
Intermittent faults are always difficult to find but here are a couple of things to check. The first is to look at the control board for a dry joint which can cause your problem. Secondly check the wiring loom where it leaves the door and goes under the machine. I have seen many breaks here as they are bent every time you open the door.The problem is that visually the wires may be good but can be broken inside.
Hope this helps & happy to assist further if needed.
Thanks for using Fixya.
  • 734 Answers
Hello just take minute to read the solution:
If the cycle doesn't complete, check these:
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
if it leaks: see where its leaking:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
Lower rack
Spray arm
Spray arm support
Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    Brigadier General:
  • Dishwashers Master
  • 3,614 Answers
Http://www.howtomendit.com/answers.php?id=153864
Posted on Nov 24, 2008
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Check the filter in the inlet pipe is clear and water pressure is OK or not. Also check...
Should take approx 22 seconds to drain.Anything more than a minute will cause a problem.
Should fill in approx 1 minute.Much more than this will cause problems.
Can you hear water whooshing around during the pre-wash....ie going through the spray arms ? If yes, then the circulation pump is working. If no, then u have a problem with the circulation pump....jammed.
Do u have a leak......water in base tray? This would operate the leak protection system, & bring the light on.
Are the spray arm jets blocked ? This would suggest the filter has not been secured fully, & possibly the circ pump has rubbish in it, causing lack of pressure to the pressure switch....making the machine think not enough water is present.
Thanks
Good Luck
    Genius:
  • 1,550 Answers
You should remove the drain line and clear it form any debris in the hose or the hose connection.
Also chance that the pump impeller is jammed.
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
211 people viewed this question
Top Dishwashers Experts
