My copier Minolta EP2030
How can I get toner/Developer adjust code or mantainence code
    Guru:
  • 389 Answers
Does not follow to do the repeated installation of developer. If you doing the installation, they will be different from factory. Minolta itself is determined concentration of the toner and after a certain time will stop the miks. Simply backfilling new portion developer and set the bank up with toner. Include the device. He stops in a certain time itself.Good luck.
Posted on Sep 13, 2009
HOW DO I SOLVE TROUBLE CODE C2557 ERROR
Image Unit fault, has the developer been replaced? Was it replaced correctly, with required counters cleared first!!! And proper test run after install? Was who ever installed new developer using a vacuum cleaner? If so might have destroyed the sensor located below the developer unit. (NEVER EVER USE A VACUUM CLEANER TO REMOVE DEVELOPER STATIC ELECTRICTY can destroy the ATDC (Automatic Toner Density Control) sensor. Toner mixes with the developer, on any Developer unit. So you could have a bad sensor or control board. As for the counters if the developer was replaced but counters not properly cleared then copier thinks the developer is old and will adjust voltage as required when in fact it is new developer which is installed and messing with image issues and causing codes. KONICAMINOLTA copiers USE THOSE COUNTERS!!!!!!!!!
Buy new developer, and replace the drum and cleaning blade also normally done together.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Try above as a start
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 15, 2015 | Konica Minolta Office Equipment & Supplies
Code cof32 appears
cof32 is telling us that ATDC sensor is reading toner supply incorrectly, now this Toner Density Control sensor sits inside the developer unit of this machine, and toner is feed into it, where the atdc sensor reads the amount of toner that it has mixed with the developer and adjust it occording to level initally set when developer was first installed.
Developer can become old and not attract the toner any more
Toner can clog up and not be able to get to it
Developer can be spilt so it is no longer at right level.
Maybe it wont stir cause of something mechanical
Sensor rarely fails
or maybe the ATDC sensor needs to reset it's level (service f8)
not sure but ...Service mode stop 00 stop 01 then select F and 8
link to new dev
http://supplydepot.com/amazing/itemdesc.asp?ic=MIN8936416&eq=&Tp
Nov 05, 2007 | Minolta Di152 Laser Printer
MACHINE HAS CODE OF F26-3. HOW DO I FIX THIS CODE?
replace the developer and run required procedures. either that or the senor that monitors the developer and toner mix is bad worse case the control board the sensor send signal to is bad
try this web site for developer
May 01, 2015 | Konica Minolta Minolta 7222 Laser Printer...
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Konica minolta bizhub 362 code 2557 for what
It's toner density sensor problem but first of all check if there is sufficient amount of developer and toner. Low quantity of developer/toner in developing unit also cause this problem.
Reference
Jun 05, 2011 | Konica Minolta Bizhub 362 Copier
C-0F32 FOR KONICA MINOLTA BIZHUB C350
Abnormally low toner density
detected Magenta ATDC Sensor
T/C 0.21 % or less is detected ten consecutive times
in the Developing Unit as validated through the toner
replenishing amount determination control.
Check Developer unit, check toner supply ratio in the service mode, under Image Process control and make sure that Toner motor is sping and adding toner into Dev. unit.
Also check and see if you have enough Developer. clean ATDC sensor and run Image Quality adjustment
Apr 13, 2010 | Konica Minolta Office Equipment & Supplies
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Hi Just bought a Konica 1212 and P.27 keeps flashing. Please can you help. I have no instructions.
Only developer should be added during a new machine set-up so that toner does not cover the TDS sensor.
To eliminate the code:
a. Access the 47 mode, output code 40, and allow the main motor to run for approximately one minute. Any excess toner surrounding the TDS should mix with the developer.
b. Perform the L-detect adjustment again (47 mode, output code 51).
c. If the problem remains, repeat steps a and b.
d. If this does not correct the problem, replace the developer and perform the L-detect adjustment.
NEED TO REPLACE THE DEVELOPER AND DO THE ABOVE WITH OUT THE BOTTLE OF TONER IN THE MACHINE ,
Jun 27, 2009 | Konica Minolta DiALTA Di200 Copier
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
107 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
