Question about Toshiba (K000823110) Motherboard
My volume does not have any sound it says that there is no volume
The realtec volume is not hooked up its not on the system
  • tekdj May 11, 2010
    What is the specs on the realtek card? It might be that the drivers aren't installed. Just dealt with that problem. Send me more info if you can & will try to help more. Here is a link that might help: http://www.realtek.com.tw/
  • 144 Answers
Install Sound Drivers..
Posted on Dec 04, 2008
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
Have only realtec audia manager but can find my normal volume botton anymore on my home pc
Hi Tania,
This problem is a 'bug' in Windows XP operating system.
Follow these steps to restore your volume button:
  • Click on 'start' & select 'Control panel' from the menu.
  • Look for the icon named 'sound' in your control panel & click on this icon to open sound properties.
  • Look for the check box with the words: "Show volume control in task bar"
  • Remove the check from the check box & click on the "apply" button at the bottom right of the properties window.
  • Now click on the check box once more to add the check once again.
  • Apply the change by clicking "Ok" at the bottom of the properties window.
Your volume control should now be visible once again in your task bar.
Don't hesitate to respond should you have any further queries.
Best wishes,
Graemevm
May 28, 2011 | Microsoft Windows XP Home Edition
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
Hai my name is shan. my pc is not have sound.i want now sound .what i do?
checkk with ur volume configuration on right side bottom of ur system. wthr its muted.. if its nt muted den u might not be having ur audio driver installed.. if u have driver cd (which is obtained while purchase) check in dat and install audio drivers and restrat.. if u dont have driver cd serch in google..wit ur pc model .. or use common audio drivers from realtec..serch in google for that
Jan 31, 2011 | Computers & Internet
Have realtec on my pc,but sound is very very low volume is on high
check the speakers from different output to check whether problem is with speakers or your motherboard. Try upgrading the sound card driver and if still problem is there so go to a system repair shop.
Jan 04, 2011 | Computers & Internet
THERE IS NO SOUND TO MY PC
Please check in your taskbar if the sound hasn't been muted and thus turn up the volume to middle.
If that is unavailable please download, extract and install the following(Please choose your Operating system)...
Realtec Sound Driver VISTA
Realtec Sound Driver XP
May 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi i have an acer 5735 aspire running vista. I cant get the sound to play when trying to listen to the radio on line. it has happened before but now no sound at all. the mute is off. The volume is up and...
Make sure that the drivers are properly installed by viewing it on Device Manager System menu located at the control panel. If there's no problem, check the sounds menu found also in the control panel then check the playback setting if it's selected to the right audio driver.
Nov 21, 2009 | Acer Aspire 5735 Notebook
Realtec hd speakers no sound ...all connections correct...computer shows speakers on..volume bar seems to show speakers working but no sound from speakers
Hi i have speackers.... but i have no realtec and i have no sound at all i tryed to look for the
volume bar buti can not find thatas well, and i do not have ac97 audio configuration as well
to ut it all together i got nothing to hear music, i hope you can help me out on this problem
please thank you.
from Debbie
Mar 09, 2009 | Dell Audio Players & Recorders
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
Toshiba (K000823110) Motherboard Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
