Question about Tanita BC550 Innerscan Body Composition Monitor Digital Scale
Just bought a BC 534 with no manual
How do I work my new scale? I have programmed it with my age ect, but can seem to get the body fat function etc. to work.
Please help.
Thanks-
  • 4 Answers
Go to www.wholesalepoint.com
They have the owners manuals on their website.
Posted on Jan 01, 2009
Programming soehnle volga
If battery replacement did not help, the scale may have failed.
Sep 19, 2016 | Soehnle 63691 Volga WhiteGrey Body Balance...
Delete User Info -
Look for your manual online and it might give you the answer
Jul 10, 2012 | Tanita BC-534 InnerScan Body Comp Scale
Need the instruction manual for the Tanita BC 534
how do you remove the glass on the printout section to clean it
Sep 22, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Tanita BC 543. I need to clear the memory held under buttons 1-4 to allow new people to use machine and update age etc
leave the scale off, and only press "set".
the scale will flash "1234"
choose your number with the ^ v arrows and press set.
all options will then be open to be set.
Jul 09, 2011 | Tanita BC-533 InnerScan Body Comp Scale
Hi. I just bought the Conair WW67WC Glass Scale... I'm following the instructions, but it won't let me set the user data. The booklet says that the height and age will flash, allowing me to change it,...
OK~Just bought the WW67WC glass Body Comp scale and its ****! that all I can say after trying to set the height, age etc etc I seem to have the same problems as everyone else. I will be returning it and buying a TANITA scale!
Thanks alot CONAIR for a ****** product.
Nov 07, 2010 | Conair Health & Beauty
Lost the manual
To learn about the scale you can download the manual on the link below right under the buy now.
http://www.tanita.com/en/.downloads/download/?file=855638025&lang=en_GB
Good Luck
May 08, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Need to reprogram my age and activity level
www.tanita.com/manuals/BC-534(1)_manua.pdf
go to that address and download the manual for free. it will tell you how to reprogram the scale.
Jan 03, 2009 | Tanita BC-534 InnerScan Body Comp Scale
Tanita BC550 Innerscan Body Composition Monitor Digital Scale Logo
262 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Tre Elkins
Ankit Chandel
Ankit Chandel
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
