Question about Saeco Magic Cappuccino Espresso&Cappuccino Machine
Leaking saeco (barista starbuck) portafilter
I cleaned whole machine inside and out. Replaced group head gasket and metal copartment that holds portafilter. Now portafilter loose and wobbley, water pouring out everywhere. Only a packed portafilter will some times work, but mostly not. I have a skamatic diagram and it still doesn't work. Any suggestion on what I didn't do, should have replaced or forgot to put in right?
The boiler and the portafiltre both are bolted together at the same time, otherwise the spacing is wrong. Took me a long time to figure it put...
Posted on Feb 10, 2011
Will a Starbucks sirena portafilter fit on a Starbucks barista?
The Sirena portafilter is 58mm and the Barista portafilter is smaller at 53mm so the two are not interchangeable.
58mm is a fairly common size in portafilters however, so if you are looking for something different for your Sirena, there are options. Also the Sirena has a rubber disc and peg to function as a self-tamper, those can be removed so you can tamp your own grind and adjust it to your liking.
Jan 26, 2015 | Saeco Starbucks Sirena Espresso Machine
La Cimbali junior group head leak after restore
Group head leaks can be caused by group gasket, portafilter basket (cup), valve, pipe fittings. Call back your service tech.
* Check group gasket and position of portafiler handle when pulling shot. The handle needs to point directly at you (your chest) if it points to your left shoulder or pops off the group then the gasket is worn, not correct size, missing spacer.
* If the handle points to the right shoulder then the gasket is, too thick, too many spacers, or it was installed without removing the old coffee (crud) from the group head and is stuck under the gasket. Remove and check group gasket and spacers.
* If the handle points directly at you but portafilter still leaks then check the basket (cup) insert. Many Barista's smash the portafilter on a bumper. If the bumper is worn and the metal bar is exposed then the basket insert will have a flat or dented lip. Check all your inserts for damage and replace worn bumper (a piece of water hose cut to size works)
* Still leaking? Remove cup tray above group and check group head for leaks around the pipes and fittings. Note: water discharge from bottom of group valve is normal DURING the pulling of a shot. It should not continue to drip water after pulling the shot.
* Still leaking? The group head needs to be checked.
* Pump, water lines, Water by-pass, Economiser, Hot water wand, and all the water fittings.
Aloha, ukeboy57 (youtube)
Feb 18, 2013 | Espresso RMI La Cimbali Espresso Machine
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks barista.Espresso drips.
There was an unusual high pressure problem, remove the shower and screw, then the 2 allen wrench screws and check the spring and valve seat, they may have shifted.
Mar 05, 2010 | Starbucks Barista Utopia
My Barista Saeco is 4 yrs.old. Pump works good in the steam cycle but bogs down in the brew cycle. Today the pump almost stopped completely. What's up?
Try cleaning your portafilter. Put a pinch of automatic dishwashing detergent in the portafilter basket only. Brew until you get suds comming out then stop for 1 minute. Repeat 5-10 times, stoping for the minute each time, until you get white foam. Then rinse basket and brew empty for a complete tank. Then try brewing again with coffee.
Dec 31, 2009 | Starbucks Barista Utopia
Starbucks barista machine steam valve leaks.
Hi Sammy,
I think you have to replace the steam valve and the gasket in it.
Best regards
/Mirran
Nov 07, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR how to clean metal filter?
The item you were refering to is: http://cerinicoffee.com/Saeco_Brew_Group_key.asp
It is used for removing the screen on brew groups: http://cerinicoffee.com/saeco_vienna_brew_Group.asp
It connects to item #4 below.brew_group_vienna5.jpg Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Magic Cappuccino Espresso&Cappuccino Machine Logo
618 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
