I believe that is due to there only being one power cord connected to the unit. Those eServers have two power cord connections in the back. If you only have one plugged it, it will cause the front indicator to show yellow instead of green.
If you do have both power cords plugged in, then you might have a bad or power unit on the system. When the system is at a safe place (BIOS/etc), try unplugging one cord at a time to see if the system shuts down. If so, then you've found your problem.
After i set 'Memory Remap='disable" on configuration and setup of ibm xseries 226,the bios dont...
(More)
After i set 'Memory Remap='disable" on configuration and setup of ibm xseries 226,the bios dont appear when i reboot the server? How can i do?
I need raid driver for win7 64 so i can install the OS the one i have found on the ibm is a exe file...
(More)
I need raid driver for win7 64 so i can install the OS the one i have found on the ibm is a exe file that wont run :/
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the...
(More)
Hi, When I go to install Server OS in my IBM server machine then I found some error regarding the HDD not found. Can you solve this?
