Question about LaCie Computers & Internet
Hi - I have only had my Lacie 500g Hard disk for a few weeks and out of nowhere it will no longer register on my Mac when plugged in. Upon turning it on it makes a whirring noise and the occasional single beep can be heard. I have not dropped it - it has been very well looked after. I am not particularly computer minded so am hoping there is an easy solution - if not please just let me know if it needs to be sent off to be fixed. Any help is greatly appreciated!
    Scholar:
  • 70 Answers
Try it out with another computer and see if it's working or not, if not try with a spare usb cable because maybe that's the case or try it out with a different kind of cable if possible like esata or firewire if possible, if still nothing, than bring it back to the shop in warranty, and maybe consider to try to get a different drive wich is made by the manufacturer who did the HDD inside it.
You can find Seagate, Western Digital and Maxtor (Maxtor is owned by Seagate) for soure.
If it turns out that it's an OSX problem than another expert is more than wellcome to sort it out.
Posted on Nov 24, 2008
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 500g wont show up on desktop
Hi, I have not read the other advice you have tried but what I can tell you is that "vary many" people have the same problem with these Lacie 500g drives. The only solution that has been found to work is unfortunatly returning it to Lacie for repair. Most other options seems to either not fix the problem or it fixes the drive for a short while and then the problem returns. :(
Sep 22, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I purchased a LaCie Rikki Go Hi Speed USB 2.0 from Microcenter and had them back-up my old MAC hard drive info onto it. When I plugged it into my newer MAC, I copied the folders onto my newer desktop that...
It could be that your new mac has a newer operating system on it, so I think you should be using the new itego backup assistant from iomega see http://www.lacie.com/products/product.htm?id=10323 this tells you what it does and you can also download it from here as well
Hope this helps
Sep 14, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
When I put my mac in sleep mode and restart it I get a message that says I have not put my lacie hard drive away right. How do you do that.
The message you are getting is refering to removing the Lacie before disconnecting it.
Just as you eject a drive before unplugging the cables to prevent corruption you must do the same before going to sleep as turning off the power to your USB ports(which happens in sleep mode) is no different than unplugging the drive without ejecting the drive when the computer is running.
If your Mac is set to go to sleep and save power when it is not in use then you should only plug your Lacie in when you are using it and should eject the Lacie before going to Sleep.
Failure to do so will eventually result in a loss of data.
If you have already lost data from a Mac formatted Lacie drive then you should refer to the below link for assistance in recovering your files, if not simply follow the above steps and you should not have any problems as a result of your Mac going to Sleep.
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Feb 11, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Not showing up
recheck to insure partitions rexcognized and reinstall unit driver.
Jun 22, 2008 | LaCie Design by F. A. Porsche 80 GB Hard...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
Computers & Internet Logo
94 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
