Question about Maytag MDE2400AYW Neptune Electric Dryer
Dryer not drying
Maytag mde2400ayw.
The machine wont dry; it does not produce heat. It still tumbles and the like, just no heat. I'm sure the obvious answer is heating element, but because I can't find a manual online, I'm having trouble specifically troubleshooting the problem.
  • 1 more comment
  • megmckenzie Jan 24, 2009
    My dryer also still works but there is no heat i have replaced the heat element and still there is not heat!! Someone said there is a relay that the heat element has to go to to heat the dryer and that could be out but where can i find that relay on the dryer???
  • Anonymous Apr 06, 2009
    No Heat
  • jvarn1002 May 02, 2009
  • 2,692 Answers
Locate the heater element ,disconnect one or both ends. ohm it out with an ohm meter. Zero reading means tha it is open and needs to be replaced. Maxium or full; scale reading on the right side means that it is shorted and needs to be replaced. Middle reading on the meter and I would look elsewhere,such as;  Voltage coming to the element if you are used to dealing with 220 volts, live.
Posted on Nov 24, 2008
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Maytag mde2400azw takes forever to dry.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Dec 27, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Front load MDE2400AZW takes forever to dry stuff. A regular load takes 1 1/2 hrs to dry,but the heat is on, and it seems to work.
Make sure the lint trap in the door is clean. It has a plastic cover that opens. Disconnect the venting at the rear and run a load, if it works you have a restriction in the hose after the dryer or in the wall past the hose.
Dec 01, 2009 | Maytag MDE2400AYW Neptune Electric Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Need to replace the igniter assembly on my dryer
remove the pannel and there will be a 1/4 inch screw there that holds the igniter on be sure that u unplug the machine BEFORE you start this to revent any electrical shock.
Apr 07, 2009 | Maytag Dryers
Maytag compact dryer low heat doesnot dry. works for hrs clothes still damp.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 02, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Front Load MAH2400AWW Washer
sounds like you have a short in control board on washer buy service smart agreement from sears it will cost a little and cover up to 500.00 or give you 500.00 towards replacement value, dryer if you have heat its your vent in wall not breathing well , it will cause long dry times
Feb 13, 2008 | Maytag MAH2400A Front Load Washer
Maytag MDE2400AYW Neptune Electric Dryer Logo
740 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
