Question about Olympus Camedia C-350 Digital Camera
I can not switch on mu camera,
My camera was doing ok when one day I took it out to take pic. when I switched it on it gave the message that the card if full. I tried to delete some of the pics but then it started giving me messages that format card or switch off option. I could not switch off my camera. It jut got held. I had to take out the bettries to switch it off. Later I tried to switch it on but it doesn't work. I showed it to some camera fixing person and he said that there is no problem with the hardware and that I should get it checkeg by Olypmus itself and they have software to detect the problem with the software and he is aso mentioned that it is expensive. Now I don't know what to do. Can any one help please.... thanks
  • SADIA IQBAL Feb 19, 2007
    Dear Jeap,
    thank you so much for information. do u have any idea how much that will cost? can there be any other reason and solution for that matter.
    i am in pakistan.
    once again thanks
    best wishes
  • 114 Answers
If the camera is under warranty it´s free....if not it could be expensive, depending where u are they will send it to portugal or to czech republic, that´s where in europe all the olympus cameras are repaired, and they don´t have such software, i know i worked there, probably tis the card slot damaged, and they will replace it.
Posted on Jan 19, 2007
Took about 50 pics and tried to see them on computer. Got the message "card locked." Now what?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 06, 2010 | Canon PowerShot SX 200 IS Digital Camera
I took pics with no memory card can i retrieve the pics on card ?
Hello
Please follow these steps:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
This should do the trick.
Kind regards
Andrea
Aug 20, 2010 | Kodak EasyShare Z740 Digital Camera
Locked card
Hello
Ok, here is something you can try:
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Aug 03, 2010 | SanDisk 2GB microSD Memory Card
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
I put a new card in my camera because my last one was full. Then I took several pictures. All of the sudden i get a message saying "memory card needs formatting." I pressed "ok" format. It deleted all of...
First of all, do you know you're supposed to download the pics from your full card to your computer and then format the card in the camera? Keeping them on the card is risky since the cards are not made for long term storage. The pics can degrade over time. Formatting completely erases a card and that's what happened with your new card. All new cards should be formatted in the camera before using....that's what your camera was trying to tell you.
Jun 23, 2010 | Kodak EasyShare CX4310 Digital Camera
Card Reader Error
There's a slide switch on one edge of the SD card. Slide it away from the contacts. If that doesn't work, there's a problem with the mechanism inside the camera that detects the switch position.
Dec 29, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Just got new easyshare, cannot review pics and pics will not copy
All cameras need a memory card of some description. A 1GB SD card would be more than big enough from any photographic shop. Make sure that the lock switch on the side of the SD card is not set.
Jun 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
MEMORY FULL ?? CD310CE
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
Jul 01, 2008 | Cameras
X-D picture error message.
Well, you can try to recover it using recovery software, but you are out of luck, it seems Olympus have some issue with memory card slot in FE model, I have FE280 and it happened to me three times already and I call the support they are no help what so ever. Answer they provide is format the card.
you can try to recover it using memory card reader, but you have to find one that support Xd slot.
Sorry to hear that you have that problem, take as lesson learn and don't buy Olympus.
Jan 27, 2008 | Olympus FE-230 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
88 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
