Question about HP Photosmart R937 Digital Camera
Hp photosmart r937 quit taking pictures but will still does video?
I didnt drop it or anything...it was in the case stored on a shelf...took out of case and moved slider to pictures and all it will do is video...any solutions or anyone know who might be able to fix it?...have had it for 3 years and i love it....dont want to have to get a new camera... :(
SOURCE:
  • 5 Answers
SOURCE: hp photosmart m425 flash no longer works
I would look to see if wires are pinched going to the flasher.
You have disassemble the camera.
I would think first before tring this.
Remove 3 screws on bottom, 1 in battery compartment, and 1 at very top of usb flap (look good).
Now slide the side piece starting at the usb flap then apply pressure to top and away from unit.
now look for 1 silver and three black screws (facing back and front, look good).
Remember to replace battery door first if it fell off during process.
*TEST NOTE: You can place batteries in and place a penny across the bottom to test before you put it back together.
Posted on Jan 19, 2008
  • 3 Answers
SOURCE: hp photosmart m415 digital camera
You can do that. In the camera setup menu scroll down to the last option "move images to card"
Posted on Jul 01, 2008
  • 3 Answers
SOURCE: How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
leethedeuce
  • 4472 Answers
SOURCE: HP PHOTOSMART R937
If you have only had it for 6 months, I would recommend sending it in to HP to be serviced.
Thanks,
Lee
Posted on Jul 21, 2008
namizhka
  • 148 Answers
SOURCE: CAMERA M425 HP PHOTOSMART
TRY TO REMOVE AGAIN THE BATTERY AND RECHARGE YOUR BATTERY PACK UNTIL IT WAS FULLY CHARGE, THEN TRY AGAIN PERFORMING THE OPERATION..
Posted on Sep 16, 2008
How do i fix a Hp Hewlett Packard photosmart r937 digital camera?
Not sure on the camera model but cameras usually don't take 12v so I would comparability of charge voltage would be the problem. Cameras take 3v to 6v usually. Check the specs of your camera that will tell you what it needs. Hope this helps.
Feb 23, 2015 | HP Hewlett Packard Photosmart R937 Digital...
HP PHOTOSMART R937
Thanks,
Lee
Jul 21, 2008 | HP Cameras
How do I find the hp r937 software
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Feb 22, 2012 | HP Photosmart R937 Digital Camera
Hello i have the hp r937 and i had dropped it and the door to the battery will not close now i think a part on the actual camera broke of not on the door is there a way to fix this?
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
Nov 22, 2009 | HP Photosmart R937 Digital Camera
I lost all my pictures. do not know why .my memory stick is still
i suppose if you have connected your camera to a system which is either virus affected or you might have deleted them accidentally. but dont worry you can retrieve the deleted photos from your memory card, for which there are softwares. you can google search for them and install them in your system.www.p-dd.mobi/ ....... the above said website contains the softwares. it is an example.
Aug 15, 2009 | HP Photosmart R937 Digital Camera
Shutter won't open
i have a hp photosmart m525 and the shutter wont open i am able to reveiw my pictures but am unable to take any pictures is there anything i can do about it?
Apr 08, 2008 | HP Photosmart M415 Digital Camera
Konica minolta dimange x50 problem..
Please advise, my dimage x50 wont focus clearly pictures are blurred is there a way to correct this?
Apr 02, 2008 | Konica Minolta DiMAGE X50 Digital Camera
Black screen when trying to take pictures
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Apr 02, 2008 | Kodak EasyShare C643 Digital Camera
Viewing lens
Mar 26, 2008 | Kodak EasyShare C643 Digital Camera
HP Photosmart E317
It obviously is broken inside.
A repair is not on the cards I suspect or at least the prince will be near the price of a replacement.
Check out HP support first though.
Nov 02, 2007 | HP Photosmart E327 Digital Camera
HP Photosmart R937 Digital Camera Logo
42 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
