Question about AudioBahn A2200HCT Car Audio Amplifier
No noise A2200HCT
I have a audiobhan A2200HCT and one day i got in my car and turned the key over with out starting it and the volume was low and as soon as the bass hit the amp popped 4 times the lights work and the cooling fans and the green lights on there is just no sound from the amp ive taken it apart looked the board over nothing seems to be burt up nothing smells funny i dont know what it is i also hooked a different amp up and it worked fine so i know it not the rca's some one please HELP!!!
  • 1 more comment
  • blockbeata09 Nov 29, 2008
    i looked the amp over agian and found the things clamped to the heatsink are cracked 4 of them are is their anywhere that sells them i think that might be it
  • blockbeata09 Nov 30, 2008
    it loos like it says irfz44n and their is another # 606p
    thanks for all your help im about to order 16 off them and replace them all. even if the transistors are cracked it will still allow the amp to power up?do you think that sounds right
  • 631 Answers
To determine what failed, you would have to open the amp while it's powered up and measure the voltage at several points. If you're not comfortable with doing this, you should pay to have it repaired. If you want to try to repair it yourself, read through the following page.
Basic Amplifier Repair
You'll need a digital multimeter.
Let me know if you want to try to repair it yourself.
Posted on Nov 25, 2008
  • Perry Babin Nov 29, 2008
    What are the numbers on the transistors?
  • Perry Babin Nov 30, 2008
    IRFZ44NPBF-ND
    You MUST replace the 8 on the side that had the 4 cracked FETs. You should replace the 8 on the other side also.
My front speakers for my onstar, backup warning and when my key is in the ignition and the door opens alarm is not working proerly. The sound is very low even though I have turned the volume all the way...
Hi
It sounds like it would more than likely be a short from some where within the wires probably a speaker wire try turning the radio of then on whilst the ignition is on. Then turn the radio back up again.
Regards Craig
Feb 01, 2018 | 2008 GMC Sierra 1500
My speaker that is for my onstar, backup warning and when my key is in the ignition and the door opens alarm is not working proerly. The sound is very low even though I have turned the volume all the way...
you have many problems in one question.
Let's start with
1. BACK UP Warning is it the backup lights not working.
2. When you open the driver's door does the inside lights turn on
maybe the system doesn't know the door is open or the little switch inside the steering column is open circuit.
3. Maybe the speaker itself defects or wiring touching metal ground
many questions that I cannot answer without more infos
hope it helps
Jan 28, 2018 | 2008 GMC Sierra 1500
I just bought a cobra 29 ltd, i hooked it up and calibrated it the way the manual said but when i turn it on and turn my squelch all the way to the left i barley hear it at all, and i have the volume all...
there may be a very low noise level. If the noise level is low you will hear almost nothing. You need to go on ch 19 and drive near a major interstate.
Key up and say, "Break one nine for a radio check" and a trucker will come back and tell you its working. If you hear him okay, then your radio is working fine.
Some days, background noise is heavier and lighter then others.
Oct 18, 2010 | Cobra 29 LTD CB Radio
When i turn the key the escape wont start it just makes a clicking noise?
That noise is probably the starter solenoid rattling because the battery charge is low. Start out with a jump or make sure the battery is fully charged up.
May 21, 2010 | 2002 Ford Escape
I want to buy a AUDIOBAHN A2200HCT amp i have a kicker 17 15 inches this amp works with this woofer thanks
will work, ive heard mixed reports about those audiobahns though, i think personaly i would stick to phenox gold,rockford fosgate,or another well known power brand. what box is it in?
Feb 04, 2010 | AudioBahn A2200HCT Car Audio Amplifier
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
My xp-50 is emitting a noise when the keys are pressed
If the level is very low, this is what is known as "digitizing noise".
The waveforms from synths being digital in nature, have sharp edges that are filtered. There is a fine line between filtering too much and too little.
There is ALSO the statistical noise that is present in electronic devices that you can notice when you turn the volume way up.
These are all NORMAL and the nature of the beasts.
Nov 28, 2009 | Music
95 Golf G3. Why won't my car start I really need help
have u checked the oil level ? some times they have a sensor and cuts off engine for safety reasons ,u should add iol if low let it set and check again
Jun 14, 2009 | 1998 Volkswagen Golf
Car wont start, contstant ticking from engine.
Locate the ticking noise. It is a relay that has gone bad.
Jan 12, 2009 | 2003 Renault 181
AudioBahn A2200HCT Car Audio Amplifier Logo
141 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
