Question about Mitsubishi WT-46805 46" Rear Projection Television
1998 mitsubishi big screen tv model vs-50603
Blue picture tube light up at the bottom but the blue ray that shines on the screen will not light up is there a bulb in this tube or is there a problem on one of the circuit boards that,s causing this tube not to light up blue i need a response as soon as possible
I have red line on my tv
Posted on Oct 31, 2010
  • 927 Answers
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Good Luck, big IRISH.
Posted on Jul 25, 2008
I GOT A 55 INCH TV MITSUBISHI MODEL # VS-55601 I GOT SOUND NO PICTURE
shine i light on the screen to see if you can see the picture .if so the back-lights are bad .
Apr 18, 2017 | Mitsubishi Televison & Video
My tv doesn't show the entire picture. I'm sure it has to be the settings but I don't know what to change it's a Mitsubishi and directv is my provider
  1. Press MENU on your remote control, select Settings in the heading, then select Television.
  2. Select Screen Aspect ratio and high definition, press OK.
  3. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  4. Press OK.
Sep 28, 2016 | Mitsubishi Televison & Video
Liquid leaking from all CRT.
the problem is not just the tubes leaking but the boards under them get damaged also,mite not be a good idea to fix this one-thats just my advise(been fixing tvs since 1978)
Sep 02, 2009 | Televison & Video
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I have a Mitsubishi VS-50603 that will not turn on.
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi vs-50603 no remote.what is code
Good Day, ariley1604;
Please contact comcast, and look into U- VERSE.
Aug 21, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Trying to get Fullscreen HD.
MY TV HAS SOUND BUT NO BIG PICTURE IT HAS A LIL PIC IN THE RIGHT HAND CORNER WHEN U PRESS MENU.
I HAVE MODEL NUMBER VS-50603
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Problems with t.v.
remove crt board one at a time,when set comes on and stays on then that tube is shorted, try red first.CRT on NECK of tube!
Nov 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
1998 mitsubishi big screen model VS-50603
this model is famous for fluid leaks. each projector tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Jan 12, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
690 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
